Re: Should I power this thing up?(I HAVE NO VARIAC)
do what do I do with all the diodes? and thermistors?
Permanently Retired Systems:
Kooky and Kool Systems
Once again, you don't have thermistors in that power amp!
Just STV-3s, bias diodes,which will be fine if undisturbed. They're mounted to the heatsink.
If you're confused as to what they are, look at the schematic. The STV-3s have diode symbols, don't they? If you don't have the sch, I''ve attached it.
The only thermistors in this unit are the ones on the prot relay PCB, for temperature compensation, so the trip point is (mostly) the same over varying ambient temperatures.
Now, is there anything else to replace? And have I gotten all of the caps to replace? I got the caps from the amp, the prot. board, and the tone board. Thank you.
my experience with old stuff,
check the power cable - is it still flexible & smooth - not stiff or cracked?
take all the fuses out (one at a time) - are all the clips still tight and springy?
power cable: yup.
fuses: most are soldered in, main fuse holder needs juuuuust a little work.
update: fixed main fuse holder
Reason: update
what to do now? is there anything else that needs replaced?
hello?
hello??????
Volume is dirty and one of the switches is dirty. Going to clean it soon. Right now, the signal strength meter is frozen.
The Marantz 2325 is going for $1,175.00, i don't get why. These fuckers are deaf! They can't pick up a 1 watt FM transmitter next to the bloody antenna! Yet a yamaha CR640 has no problem picking it up from across the room! Marantz garbage!
While I will say prices have gone INSANE with these, the particular unit you have seems to need a tuner alignment very badly. The tuners in these are quite sensitive if they're operating properly.
I'd also recap that voltage regulator board and adjust its output. The tuner won't work for crap if it's out of whack.
