Does anything less than 470uF or 1000uF usually bulge ?
Does anything less than 470uF usually bulge?
Re: Does anything less than 470uF usually bulge?
its less likely but by "no means rule it out", its still very possible
As with any cap it depends on the circuit and how its being used (or abused) heat around it etc
Type of brand/series also is it crap brand cap.
So as above at lest check/test them.
CheersYou step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
They usually don't vent, but since they are so small there is so little gas that could possibly build up so even if they have failed they still may not bulge..."The one who says it cannot be done should never interrupt the one who is doing it."
1000uF bulging is very common.
Like everyone else said about the 470's, it less likely but it happens.
As I recall some of the 470uF you asked about in the other thread are 8mm.
An 8mm 470 is -probably- more likely to bulge than say a 5mm 470.
Failed caps don't always bulge.
But bulged caps are always failed.
.Mann-Made Global Warming.
- Dr Seuss
ESR meter or caps meter are always our best tool. Need to check the old caps by these meters even it is a good caps brand.
I've seen a lot of LELON 470uF and 220uF caps fail. However, as a rule, caps below 1000uF tend not to fail. A lot depends on the brand, LELON being the most common for sub-1000uF caps failing.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Right now in my "to do" boxes I have
2 bloated leaking 470/16v [8mm] Elite on an LCD inverter board.
2 bloated leaking 470/16v [8mm] Fuhjyyu (1 each in 2 different) Antec power supplies.
4 slightly plump 220/10v [6mm] Chhsi (2 each in 2 different) MSI boards.
And something between 100 and 200 various 1000uF to do.
The small ones bloat just not as often as larger caps.
- Dr Seuss
Oops, brain fart...
The 470uF Fuhjyyu in the Antecs are 25v.
- Dr Seuss
Originally posted by larrymoencurlyWhat about 0.1uF electrolytics?
Why do they use electrolytics that small instead of ceramics?
That's a good enough theory question to warrant it's own thread so I made one here:
https://www.badcaps.net/forum/showthread.php?p=85736
- Dr Seuss
I had bulging 470uF Hermei in an LCD monitor
But I also replaced the 22uF and 1uF Elites with Rubycons anyway
I guess the only real way to know is with the ESR and capacitance meter... (which I don't have yet) so I just replaced the lot. Makes me feel better anyway"Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHorn
I've had multiple 100uF and 220uF bulgers on different boards.
Usually Intel boards where they used 85c for the small diameter caps compounded by poor cooling from clogged fans.Last edited by PCBONEZ; 11-08-2009, 12:56 AM.Mann-Made Global Warming.
- Dr Seuss
1 So they will fail
2 because eletrolytics tend to have less resistance across them over ceramics.
With LCD monitor repairs I find it quite common pulling badly bulged 470uf and 1000uf caps, especially those that are physically small for their designed capacitance. I also have observed bad caps down to 1uf, but I would agree apparent bulging in low farad cans is not common, vented or not.
But if you're thinking of leaving small caps on the board, consider that testing of the caps I've pulled, shows a good 50 % test OK with a good ESR meter...so why did I pull them ? Its like when a good mechanic tears and engine down for repairs, he doesn't just replace one valve or one ring or one bearing, he replaces them all for much increased life and reliability for a minimum of expense while the job is being done. So the extra few minutes and that extra buck or two replacing those caps on your board, will pay off in the long haul. Besides where's the fun... if you cut and run ?
