I had some thoughts about the real life expectancy of a CPU. Knowing that electromigration and heat plays a large role in their life expectancy, how long in years the cpu is expected to function ok at 100% load? Obviously, considering normal case temperatures, not overclocking, and 24/7 running.
I can't found data about this in datasheets from the two biggest PC processor manufacturers.
I think there should be diferences between CPU models and generations, mainly because of diferent fabrication process tecnologies (250nm vs 065nm, for example) that makes transistors and interconnections more small and prone to electromigration more easily. But, electromigration is a real issue in long time or just a myth?
In your's experiences, how long usually lasts a processor at 100% load?
Thanks!
Thanks!
