thinkpad a485 bios password
    i have a thinkpad a485 with bios password i tried lenovo patcher but the pc has no power with patched bios
    any help pls
    Re: thinkpad a485 bios password
    mee too also i need patcher for 2 pcs
      let try with it
        Hi
        Not working
        Only beeping
        Tamper pressed and hdd removed
        Thank you
          Originally posted by vinsun0399 View Post
          let try with it
          Can you try to patch again?
            @mariox13
            Try
              Originally posted by onizzbox View Post
              @mariox13
              Try
              Hi and sorry for late answer
              Both of them freezing at enetering setup .
              Thank You for your patience
                Anybody have metod to unlock bios im A485?
                  send bin file
                    late but I'm posting
                    try
                      help me
                        Originally posted by dimkka View Post
                        help me
                        a485 is amd one not intel
                          Kindly please with password of Lenovo A485 Ryzen 5
                            read again your bios, it has an error. Length is 16.777.215 bytes and should be 16.777.216 bytes
                            all donations are welcome,
                              Correct one. Sorry for mistake.
                                try this and follow the steps:
                                [ HOW TO USE THE PATCH ]
                                STEP 1: Flash and replace current BIOS with the generated patch file
                                STEP 2: Boot the machine
                                STEP 3: Press ENTER/F1/etc. to enter BIOS settings
                                STEP 4: Enter any character when asked for Supervisor Password
                                STEP 5: Press enter when it shows Hardware ID
                                STEP 6: Press space bar 2x when asked
                                STEP 7: Turn off machine
                                STEP 8: Restore original BIOS
                                STEP 9: Reset BIOS settings to factory default
                                [ NOTES ]
                                When booting the patched BIOS you might have to:
                                - Hold the anti-tamper switch down the whole time (use tape)
                                - Remove the hard disk or replace it with a locked one
                                  Do you did your own modification, or jut use autopatcher tool from forum?
                                  I tried with autopatcher without success at A485.
                                    The answer to your questions lies within them.
                                    Obviously, since you've used the patcher to no avail, but the new file worked it clearly contains a "own modification".
                                    Become a Badcaps supporter
                                    Thanks to all supporters.​
                                      was not made with autopatcher.
                                        Now get ready to answer more questions, I'm sure you can imagine what they might be. Take my advice and prepare a pizza and Diet Coke too, just in case.
