9v super basic wall wart issue
    This is one of those worthless and time wasting repairs but it's bugging me and I want to figure it out. Simple 9v 1a SMPS wall wart and it's bouncing between 8.2 and 9.4v without load. I've pulled out every single cap and all tested fine. I've replaced the opto and same exact issue. All diodes are testing fine. I'm not sure if the IC can cause this or if the IC had issues you wouldn't get anything at all on output.
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
    Re: 9v super basic wall wart issue
    power supplies tend to have minimum load, does it surge with some load?
      I'll check later tonight
      Ryzen 3600x
      FX-8802 Iron
        Replace that small electrolytic C3
          Look if C3 has something to with the feedback and change it.
            I wonder if C3 might be the issue
              The 431 may be hunting.
              Try a 150-1k resistor across the IR LED in the opto.
              Points are marked in attached image.
              Change the small cap on pri side to 22u/50v or 47u/50v.
              "pokemon go... to hell!"
              EOL it...
              All style and no substance.
              guilty,guilty,guilty,guilty!
              guilty of being cheap-made!
                I pulled all caps one by one and they all checked out. I can replace it anyway but don't know what good it will do
                Ryzen 3600x
                FX-8802 Iron
                  9.21v stable. How do I know which one fixed it? Replacing C3 or adding a 330ohm resistor to the opto?
                  Ok, pulled the resistor off and it's still good. Pulled C3 which was a 10uf 50v cap and replaced with a Panasonic FC 47uf 50v.
                  Ryzen 3600x
                  FX-8802 Iron
                    Soldering heat from R&R'ing C3 may have temporarily "woken" it up.
                    The 431 seems to need a minimum load; when an unbypassed opto LED is the sole source of current to the 431, the latter can hunt.
                    Leading to voltage "bounce" at no load.
                    Perhaps it was C3.
                    With the original C3 in place, leave it out in the cold a while- it'll probably act up afterwards= cap(s) is/were suspect.
                    In similar SMPS wall warts, I've used 22-47u/50v caps, PW/HE/FC, for C3.
                    If a new C3 keeps it stable, even cold, you can probably leave the opto LED unbypassed.
                    EOL it...
                      Perhaps it was C3.
                      The 431 is the small voltage reference SOT23 part?
                      Ryzen 3600x
                      FX-8802 Iron
                        BTW, got home and still tested very stable around 9.2v.
                        Ryzen 3600x
                        FX-8802 Iron
                          glad you got it fixed! I ran into a similar issue before on a different power supply where it only supplied half of the voltage.
