I have lenovo ideapad 130 15ikb with i7 8550U and has no dedicated graphics card, there is an strange issue
The problem is it impossible to install windows 10 (I did not try to install windows 7)
The actual problem is , win 10 setup starts well and after finished copying necessary files (%100) and request an restart, then 2 nd part of setup is not working and it gives an BSOD (Blue screen) says that CRITICAL PROCESS DIED and setup doesn't continue.
What I did:
1-Laptop boots normal, bios accessible, no bogus screen, everything seems working normal
2-I services the cooling system (clean fan replaced thermal paste with good quality) and it has no cpu overheating issue
3-I checked the hard drive , full scanned the surface by connecting to another computer it has no even a tiny bad sector , and disk is healthy and it's %100 so it's not and hard disk issue
4-I checked the Rams with MemTest86+ and it has no errors (the computer boots normal and on DOS there is no problem only unable to install windows 10
5-I used different USB 's port and flash disk try to install both UEFI , and Leagency but both same , gives BSOD as CRITICAL PROCESS DIED after copying installation files
What might be the problem?? I think its motherboard issue ?? Or its bios ?? , please help , I am going to mad 😀😃😁
What I did:
