List of pin compatible Laptop ICs
This is a sticky topic.
    Re: List of pin compatible Laptop ICs
    HI
    is this IC have compatible replacement?
    G5616..
    thanks.
      Originally posted by joselito View Post
      HI
      G5616..
      thanks.
      Seem compatible with RT8207 family, just make sure the package TQFN3X3-20/WQFN-20L 3x3 or TQFN4X4-24/WQFN-24L 4x4
      compare its both pin out with according datasheet each vendor
      https://cdn.badcaps-static.com/pdfs/...6218c2ffb1.pdf
      https://cdn.badcaps-static.com/pdfs/...fa9f34c8a3.pdf
        Thanks for sharing
          please hp15-d030se 03011NG00-600-G bios Please
            Originally posted by highpulse View Post
            max 8731ae , wich one can be compatible ?
            getting a similar one might be a hard shell to crack. I'd rather check in dell vostro 1000.
              can i use a TPS51216 or BQ 727 as replacement of TPS 51716 in DELL INSPIR0N 15-3000
                Any RT9024PE replacement?
                  rt 8223b compatible ic???
                    216-0774207 can replace 216-0771009, done just now on HP G62. It's a "newer" family too, likely based on the same architecture but it is seen as an upgrade - 6300 series vs 5400 series.
                    A working TV? How boring!
                      Dear All member i need help about this chip with number "2n=2m" or any website where i can find this code
                        What is the board you're working at?
                          2n=
                          https://cdn.badcaps-static.com/pdfs/...d7b1efab2b.pdf
                            Nuvoton sio npce795pa0dx alternate so that i can fix my dell n5110 laptop. And any one has pinout of this chip please give.
                              Can I replace 25Q80BV for example for 25Q64FV? First one is 8mbit, second 64mbit but otherwise should be the same.
                                No replace 25q80bv =1mb
                                25q64fv=8mb if u replace any 3v 1mb chip is working.if 8mb replace same 3v working all.8mb some chip 1.8v working.
                                  Are HM70, HM75 and HM76 interchangeable?
                                    you can replace hm70 with hm76 ,and vice verca, but keep in mind that hm70 supports only celeron and pentium cpu`s so if you have better cpu onboard it won`t work for it...
                                      Thank you Djosla for the info!!!
                                        Correction, original chip was 216-0774009 not 216-0771009. Writing was rubbed off a little.
                                          Thank you
