HP dv5-1225ee (DAQT6GMB8B0) Freez at POST
    I have HP dv5-1225ee (DAQT6GMB8B0) freezes it self at POST screen.I flashed the BIOS with latest update but nothing changed.If i pressed "Esc" button from the beginning of power up nothing showed but if i do nothing then it shows POST screen and froze.
    01. I changed RAM
    02. Remove all the attached devices
    03. Re flashed BIOS with latest update.
    04. Replaced new RTC battery.
    Someone please tell me where dig for a solution....?
    Re: HP dv5-1225ee (DAQT6GMB8B0) Freez at POST
    might be graphic chip.reballing or changing may help.
    sigpic
      tried without keyboard ?
        Update:
        KB3926QF heat badly when laptop is powering up.
          I think is not relates to GPU. KB is heating badly. I dont have spare new KB but i have another one on damaged MOBO.
          Shall I try it with this one or do i need to check why is this KB heating?
            if its heating without keyboard plugged, change the KBC without a clue
              Yeap. Its heating without the keyboard.Thanks for the advice. I will change the KB and let you guyz the results.
                Placa DAQT6GMB8B0
