that pin probably wont bend, cut it so it wont go into the board.
then put the connector on the board and put a thick jump wire between the back of the socket and the place the 3 inductors went to.
then test it.
if it works and charges, we can do it better with the inductors and cap back in use.
Hi everyone im not able to make a new post because im a new momber but i hop to get your help about my probook 650 : i need bios fil ,the part number of yhe mainboard is 6050a2566301-mb-a03
Before your Sugestion i've tried this (photo) :
Once i approach the Ground to any of the - Poles, i get sparks .
As you can see, i continue to grind/sand, and the short is still present on this area.
EDIT: in my humble opinion, the short is on the - ground side, then i'm ....
