hp 14-am096tu system fan error 90b
    Re: hp 14-am096tu system fan error 90b
    @SMDFLEA the two caps near fan connector is connected to ic with a marked S32B 5388
      @ON/OFF the board id isINERINL-6050A2822501-MB-A01
        @KMMOTOCROSS the 5 leg chip has marke 58IC
          anyone please help on this
            anyone can help on this please still I havent solved this issue
              Test Voltage on all pins of this IC & mesure resistance Diode mode to GND all pins
                the voltages on each pin1=0v pin2=0v goes to ground on continuity pin3=0v
                pin4=3.3v pinv=0v. on diode mode pin1= 0.500 pin2=0 pin3=0.700 pin4=0.600 pin5=0.500
                  Assume pin 2 is the GND of this IC the rest of the pin's seams to be fine
                  If Pin 4 is the enable Signal to Drive Swatch on +5V to Fan & HHD you are missing +5V input
                  What if you put a jumper +5V to fan & HHD and see if the problem goes off
                  Replace those 2 caps if you can
                  i found a 5 leg chip near on dvd connector the pin with the red marked is connected to the caps on the hdd and fan side if you inject 5v there the fan spins
                  What pin of the 5 Leg ic did you inject 5V ?
                    if i injeck 5v on pin 5 on the ic the fan turns on because this pin is connector to the capacitor near the hdd connector and two caps near the fan connector
                      I think this series have 2 variant model, one fanless and next with fan.
                      Link HD image:
                      https://drive.google.com/open?id=0Bw...0hQTHdYaE1VQUU
                      Credit to Rimas
