I have a Samsung Model UN55ES7150F and it was striken by the lightning during viewing. The A5 volts is present on the Power supply, so I decided to Purchase a Board from Ebay . When board arrives a install it and when i Power it ON , it Blinks 2 times. Do you have any ideas what is the problem? Thanks.
samsung tv 2 blinking red light codes
Re: samsung tv 2 blinking red light codes
Samsung TVs don't have blink codes and the front LED blinks when it is booting up. When the front LED is off, the TV is in an on state and turning it off should cause the front LED to go red.
Test 1 for Samsungs - Disconnect the cable between the main and power supply and plug the TV in. The backlights should come on. If no backlights, they are suspect and bad backlights can damage the power supply.
Test 2 - Power up the TV with only one side connected between the tcon and panel. Unplug when switching sides. If one side displays half an image, you have a panel fault on the bad side.
