Hi Folks,
First day and first post on Bad Caps so I apologize if I am missing some info or have formatting issues.
I picked up this Toshiba Tv for free off kijiji and am trying to get it working again. When plugged in the On indicator goes green then there is a 1 second flicker of the LED's. I found a couple bad LED's on the bottom row and replaced them individually however the issue persists. When using diode mode all the led's faintly turn on but when my leads are reversed THE ONES THAT HAVE BEEN REPLACED SHOW OL while old ones give .75
These are the led's I ordered. The picture attached is a original led.
https://www.digikey.ca/en/products/d...5AIoHAEIAugL5A
My question is what should the correct led's be and is this what is causing the flicker?
Model: 58L1350UC
Fabricated: November 2013
SN: D47267T18198C1
AC in: 120V 60Hz
5V 3.3V and 12V all seem ok.
For the led
LB1+ LB2+ LB3+ LB4+ LB5+. all 120V
LB1- 0V. the rest 20V
Thanks in advance for any help and input.
Model: 58L1350UC
SN: D47267T18198C1
AC in: 120V 60Hz
For the led
