Sony KD-65XD9305 - DPS fault
    I'm due to remove a faulty DPS board for this TV today. I know they are a common fault in various Sony sets. I'm just wondering what actually goes faulty on these boards?
    I've read it's a certain IC, although I don't know which one it could be and that the fix is a different version of this chip.
    Any pointers?
    Many Thanks,
    Matt
    Re: Sony KD-65XD9305 - DPS fault
    Do you know for sure it's the DPS board ? https://www.sony.co.uk/electronics/s...icles/00180172
      Not yet, but I know it's very common for a dead set.
      I've seen the free repair, but i've been asked to repair rather than get Sony involved - not sure the free repair works with second-hand units either.
        This might help ..
        but i think the chip is TPS54334DDA goes on these and a fuse..
        IC408 and an smd fuse, F404 fitted to the DPS board.
        These were the parts being sold for a repair kit.
        I tried it on a set but it did not work for me.
        and did not have time to investigate further
        maybe it will be better for you
          this may help too
          https://www.berlin-repariert.de/sony...eine-funktion/
          use translate read
            Originally posted by zomi View Post
            this may help too
            use translate read
            Many Thanks Zomi, that's excellent information.
            Much obliged
              No problem
              please update the thread to let us know how u get on
              thanks
                Quick update,
                Tested the DPS in-situ, 24volts present on both sides of Fuse F404. No output from the TPS54334. SW Output resistance to ground is 8 Ohms.
                Removed IC from the board, 8 Ohm resistance present between SW output and GND. Ordered replacement IC.
                Found another DPS board on eBay listed as new and appears to have a resistor mod. See attached photo. My guess is it's either a 12K or 82K Ohm resistor to strap the PGOOD pin on the TPS54334 to GND - A strange mod as the Datasheet suggests this pin should be pulled up to VDD (max 6v) using a 100K Ohm resistor. Would be interested to know how this mod works? On original board the PGOOD pin seems to be floating?
                Cheers,
                Matt
                  TV is now fixed!
                  Replaced TPS54334, tied PGOOD pin to Ground via 100k resistor instead of leaving it floating.
                  Cheers,
                  Matt
