Toshiba c50 short
    Toshiba c50 short
    HI
    i have toshiba c50-a PT10F UMA MB REV:2.1
    motherbard has a short , the short appears only when i put the cpu and the cpu becomes hot
    i change 2 tantilium caps in cpu cirtcuit but same problem .
    no short when the motherboard without cpu .
    i check the motherboard no shorted components .
    Re: Toshiba c50 short
    did you try a different cpu as a sanity check ?
      Yes i try another working CPU but same problem .
        CPU VCORE supply coils may show low ohm. Like 6 0hm. What are your voltage measurements when you plug in a processor. it is normal to heat up without cooler.
        I'm not happy to be so strong. because it's not humanly
          thank you
          i found 2 bad tantlium caps an a mosfet.
            pls help help missing VGFX .
            HI
            toshiba c50 PT10F
            coming with no power , i found a mofet and 2 bad tantlum caps making short
            i replace them the laptop power on but without display
            mosft and caps for VGFX COR , VGFX core is missing
            isl 95836 has vdd and vron but no output VGFX
            i replace isl but same problem
            i flash main and ec bios with working file but same problem
            i have 19v on q8010
            pls help .
              any help ?
                i repaire the motheroard
                the probem of VGFX core is resistor .
