Reballing Laptop CPU upgrade
    Hi people I'm here for this reason
    I need to find out how much temperature does it need the i7-8750h to remove the processor from the board and how much temperature does it need the i9-9980hk to get soldered
    Re: Reballing Laptop CPU upgrade
    all the same by used balls
      And that what does it mean?
        These are SOC and are very delicate. The temperature profile varies between bga machines. Mention your brand/model of bga machine here so that someone can help. However, it cannot be done by hot air gun.
          It is an Aorus 15x9 i have aida 64 wanna take a look from that program?
            If you intend to do the job without professional tools (and have no experience) the failure rate will be 95%+ .With such an expensive board and CPU its recommended you take the board to a repair shop with a good reputation and have them do it.If one isn`t available in your area there are many repair shops in your country and worldwide that do mail-in,you can send it in a parcel.
              Without professional tools and experience=100% Failure, not even 95%.
                if somebody ask for temperature to desolder and solder i bet it is 120%
                  Ha Ha
