Hello everyone, the pc in question does not recognize any type of original dell battery charger. Consequently it does not charge the battery. Can you help me? Thank you
Dell 5580, ac adapter not recognized.
Re: Dell 5580, ac adapter not recognized.
Resistance to ground, and voltage at PL3 is...?----------------------------------------------------------------------------------------------------------------------------------------------------------
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..
Originally posted by drdom View PostI can't find the position of PL3, on PL4 the voltage is 19.54, the resistance to ground is 2.75k----------------------------------------------------------------------------------------------------------------------------------------------------------
Originally posted by Vesko356 View PostVoltage and resistance to ground on PL4 is OK, but is not important for your problem. So you must find PL3 and measure values if you want the problem to be solved. Don't be lazy - disassemble the machine, remove the board and find the PL3.
thank you so much
