need bios for HP Probook 4441s
    i need bios for HP Probook 4441s.
    please share.
    thanks.
    Re: need bios for HP Probook 4441s
    Just download it from HP. They offer full bios files in their flasher. And actually have a bad flash recovery processes built into their Probook and Elitebook series. No need to even open these units if you have a bad bios flash.
    Make a Fat32 partition of 2GB on a USB stick called HP_TOOLS. place bios in there for your model according to their recovery instruction. Boot the unit holding the recovery keys, and you're back in business.
    Reference for you http://support.hp.com/us-en/document/c02693833
      or post your old bios dump here and i will help you
      Im Back... sort of...
        The probooks and elitebooks will not flash a bios with out a Sig file that matches the binary. so a dump obviously wont have a sig.
        I've tried flashing a dump back to my Elitebook, and it always rejects it. Force flashed it to the SPi chip and it refused to boot. Had to recover the bios. HP's bios are encrypted and are signed via RSA. This is the same reason why no one to this date has removed the white-lists from these bioses as far as i have found.
        "That .sig file is unique and will not verify any other roms expect the one it was made for. So any modifications to the bios will require a new .sig in order to flash it via efi. Unfortunately we can only generate the .sig when the bios is previously encrypted by HP or if we know HP's private RSA key."
        If you have a corrupted bios the way to recover it is with the suggestion i made earlier. If your trying to modify it, the machine will refuse to boot on it and will need the bios recovered, if you force flash it. If you use HP's built in recovery to flash it or their flash tool it will just tell you its invalid.
          @JeffJ
          you are wrong for some aspect
          @masud
          backup old bios and try both
          first file dump from some laptop, not mine dump
          second file some of my work
          pls try both
            ala_Borbe Thnk's Man
              good bro....
                thanks you.
                  thanks
                    thanks
                      thnx
                          It freeze at HP logo.
                            @JeffJ
                            @masud
                            pls try both
                            Is it working for Discrete motherboard ?. I upload it. its working showing logo only there is no vcc_gfxcore and gfx coil also not giving power. and its freezes on that logo stage. no response on keyboard or usb. There is no old bios chip on this motherboard. someone has removed it already.
