Eeprom dump thread!
This is a sticky topic.
    Re: Eeprom dump thread!
    Very, very low : CH341A.
      Originally posted by superg View Post
      what is the best eeprom programmer to use?
      The CH341A is very cheap and works just fine, I suggest to buy a sop8 socket (200mm) and use hot hair, the clip is tempting but I found very often I can't use it because there's an heatsink too near or the programmer just doesn't recognize the chip when is still on the board.
      Another user in another thread linked me this russian forum, a guy made a program to flash the chips and it's free, the program you often find on websites (by skygz) and even the sellers of the programmer link to you is actually not free.
        LG 42LK430 eax64290501(0)
        EEPROM / FLASH.
          Originally posted by Acca View Post
          Does someone have the dump for a
          TP.MS3463S.PB801 with panel k420wdkb
          It's a 42" Philips, I've tried some dumps from some 40" but the picture isn't right
          I've fixed this tv with the help from another forum, I'm sharing the files with you guys.
          42PFS4012_12_FZ1_SDA17110434.zip contains the update file, just extract the file to an usb drive (do NOT rename the file), plug it in the tv, plug the tv and what for the led to flash fast. After a while unplug the tv, unplug the usb, reboot.
          The other file is the dump of the 25Q64 I took after a factory reset of the tv.
            LG LED TV 47LN5400-ZA.BEEYLJG CHASSIS:LT36B
            Panel:LC470DUE(SF)(R1)
            Tcon:6870C-0444A
            LC470DUE-SFR1 Ver:1.0
            6C3060 3152B1
            SMPS:EAX64905501(2.0) REV:1.0
            MB:EAX64891403(1.0)
            WCM3325-02499 EBT62443501(LABEL)
            47 50LN5400LGD EBR75890815
            IC1300 V03,07,00 BE14SAA38340617
            ECO1-0 LG1303-147 26,03,S2,L2
            EEprom:IC104 4HA7D2K2(AT24C256) 0X007317F4
            Flesh:IC1300 MX25L8006E 0X09AEC854
            Nand:IC102 K9F1G08U0D 0X1FD86A2C
              Anybody have eeprom dump for IC1600 winbond 25q64fvsig
              Panasonic TX-50AX802B
              Board TXN/A1YWUB TNPH1100
                https://drivers.softpedia.com/get/TV...re-3-128.shtml
                  This is the original firmware which need to be flashed via usb, I need Eeprom dump
                    Hi All
                    My friend inserted his mobile into his Sony 60 inch smarttv..as soon as he did this,the tv froze and switched off,I think he needs a software update...I'm lookig for update for
                    Sony Kd-60x6700e ....
                    Thanks in advance
                      I am looking for DUMP TP.SIS231.PT82
                        https://www.4shared.com/web/q/#query=%20TP.SIS231.PT82
                          Hi Everyone,
                          Does anyone have the dump for a Toshiba 32D1334DB, screen VES315WNDL-01?
                          Thank you.
                            Originally posted by antas View Post
                            Hi Everyone,
                            Thank you.
                            This might work?
                              have everyone a dump for a T.V56.031 Board please?
                              On the Board there is a TSUMV56RUU-Z1 Chip
                              i searched a lot and found only defect/old Links
                                Please , please does anyone have Eeprom files for philips 49PUS6162
                                  Originally posted by jellytot View Post
                                  This might work?
                                  It's unbelievable. It just working perfectly.
                                  Thank you, jellytot, sooo much.
                                    think s for all
                                      you did't mentioned resolution here is most common 1366X768
                                        Great! Thanks for the confirmation
                                          Hello, does anyone have the dump for haier le39m7000cf?
                                          MB: T.SIS231.T701
                                          Panel: T390HVN04-V0
                                          TiA
