Sony KDL-47V5100
    Sony KDL-47V5100
    Picked this tv up for $10. The backlight comes on as seen in the picture but nothing on the screen.
    At this point I'm thinking it's a mainboard issue.
    If needed I can take readings if you want.
    Re: Sony KDL-47V5100
    Maybe take the shield off the tcon board and see if you have about 12 volts on each side of the fuse, black probe- on chassis ground, red probe+ on each side of fuse.
      Yes, 12v on each side.
        What happen if you have ribbon cables between T-CON and the LCD panel connected one at a time?
        Can we see good clear pictures of the T-CON board?
          T-con.
          No change when trying either ribbon disconnected.
            Try the test in my post #4.
              Sorry. I edited my above post to say that didn’t change anything. Didn’t see you had posted again. Trying to avoid too many posts.
                Typo in the title also. It’s a KDL-46V5100
                  Do you have a solid green led on the front?
                    No, just a solid red standby and amber pic off/timer led.
                    I also just noticed the backlight turns off after about 15 seconds and then come back on. It repeats that, nit sure if it’s because the shield and heat sinks are off of the t-con.
                    I will put it back on this afternoon.
                    Also it doesn’t respond to the side buttons. I have to plug it in and unplug it. I don’t hav the remote.
                      Should I toss it?
                        I also just noticed the backlight turns off after about 15 seconds and then come back on. It repeats that, nit sure if it's because the shield and heat sinks are off of the t-con.
                        Also it doesn't respond to the side buttons. I have to plug it in and unplug it. I don't hav the remote.
                        Aha, important info.
                        What happen if you disconnect HSR board connector?
                        Service manual:
                          Already tried disconnecting the buttons. I’m assuming that’s what HSR board is? No difference.
                            Already tried disconnecting the buttons. I'm assuming that's what HSR board is? No difference.
                            Nope!
                            Did you download the service manual to know where HSR board is?
                            https://www.shopjimmy.com/catalogsea...?q=KDL-46V5100
                              Yes I downloaded it. Didn’t see a reference. I did a search fir HSR. I’ll check again.
                                Look at shopjimmy link to see what the HSR look like.
                                  Found it, no change. Btw, it's different than the one on shopjimmy. Only 1 connector.
                                    Did you try a firmware update? One there says for 46V5100, did not see 47V5100, maybe recheck model number: https://www.sony.com/electronics/sup...loads/W0006532
                                      Yes I tried a firmware update. Didn’t work. I corrected the model number in post #8. I couldn’t change the title.
                                        Ok, didn't see post 8, what do you get if you have cable from powerboard to mainboard unhooked and plug ac into powerboard? Did you try the update with a different thumb drive? before anyone says it's a sony not a samsung, just don't.
