I would be open to a 24 volt @ 5 amp switching power supply that can be adjusted down to 21 volts permanently and the over load protection is still functional and low voltage cutoff 15 volt or higher if necessary
I would rather not have to use a buck converter to get the voltage that I need
So is anyone else that has successfully modify one for a slight lower voltage had good results willing to share with me the safest way to accomplish this task
I googled for a 21 volt switching power supply and did not find very much information for switching power supply for above 4 amps I want something more like 6 to 8 amps for the battery pack for my battery operated air compressor
I would prefer a meanwell switching power supply if possible but would consider other brands if necessary if you have had good results
