DA0U82MB6D0 Bios & EC Files
    Re: Need Bios Dump HP 15-n234sl BID 02165
    Originally posted by Simpletek View Post
    Need bios dump for hp 15-n234sl Board ID 02165, from hp site the bios is encrypted, thanks.
    Need 15 N U82 BIOS Programming
      Originally posted by Ramee View Post
      What is the motherboard code?
      need hp 15-N U82 bios programming
        Re: Need Bios For DA0U82MB6D0 Rev D
        thank qqq
          Hi I hope you need help file hp 15-n009se bios
          DA0U82MB6D0 REV.D
          thank you
          Mohammed Mohan
            Re: Hi I hope you need help file hp 15-n009se bios
            Try form HP official web site....
              Thank you my friend but I tried the files and the device did not work
              The old programming file works but does not display Is there a solution Thank you
              Mohammed Mohan
                post your backup please..
                  Unfortunately the file is lost
                  Mohammed Mohan
                    here you go:
                      Thank you . I tried the file unfortunately the device did not work
                      Mohammed Mohan
                        the bios file was tested, and it's ok, check if you have touched a resistor around the bios chip.
                          Mohammed Mohan
                            Thank you for replying . I made sure the resistor around the chip is no problem. But I'm sure the problem is in the Bios
                            But unfortunately lost the file
                            Mohammed Mohan
                              Dear friend, I dont think its a bios issue. Sourcebf has given you hp official dumps and polytek says his dump is tested ok. Check with signals like 3V/5V/15vALW, pch_RSMRST, SLP S3/SLP S4/5V-3V RUN ,1.5V RUN ETC.
                                thank you
                                  thanks
                                    thank you
                                      Re: HP 15-n015st - DA0U82MB6D0 Bios & EC Files
                                        thanks
                                          HP 15-n204ex - i5-NVidia
                                          MB : DA0U82MB6D0
                                          Board don't start . Until i clear Cmos ,remove main battery too.after that it works fine . Till i shut down . updated bios from HP site.
                                          still same problem .
