Latitude E7450 LA-A961P BIOS and EC Clean
    I need to clean ME from this BIOS. I don't know which image is the bios, in case you need more info please let me know.
    Thank you
    Re: Latitude E7450 LA-A961P BIOS and EC Clean
    Thank you
    What's problem with BIOS?
      The laptop won't power on immediately after attaching the power supply or connecting the battery. Also it won't charge. Everything will work only after roughly 5 minutes after I attached the power supply. I have an open thread here in case you want to see more information: https://www.badcaps.net/forum/showthread.php?t=100866.
      Should I merge the two dump in one or it's okay like how I've attached it? In case you need a single file can you tell me how to merge and split the two images?
        Try the bios at post #6 - https://www.badcaps.net/forum/showthread.php?t=76932
          Originally posted by SMDFlea View Post
          I already tried to flash that image, but is for non v-pro machine.
          Then I flashed the two images from post #8. Once programmed and resoldered back the chips upon attaching the psu to the board nothing happened, no blink. I tried to press to power on and after few press it started powering up but I didn't have the screen attached to the board. So i detached the psu, attached the display cable to the board and after attaching the psu back I tried to press the button. This time nothing happened, neither after few presses or after waiting some minutes.
          Should I try to flash again? Thanks
