unlock bios for dell latitude 3520
    Re: unlock bios for dell latitude 3520
    Originally posted by gustavo68 View Post
    Buenas tardes, necesitaria desbloquear la bios de una dell latitude 3520, adjunto bios bloqueada, gracias.
    Is it a New model this lenovo ideapad 3520
    1st boot, press F2, write service tag, disable Absolute, save, restart. 2nd boot press Alt+F to exit manufacturing mode.
      Dell latitude 3520
      Hi friends
      pls helpme to unlock this dump
      dell latitude 3520
      service tag 6yt0kg3
      thanks in advanced
        Re: Dell latitude 3520
        Originally posted by Murtaza527 View Post
        Hi friends
        dell latitude 3520
        service tag 6yt0kg3
        thanks in advanced
        Suffix !
          Hi friends
          dell latitude 3520
          service tag 6yt0kg3
          thanks in advanced
            I would like to ask for help in unlocking the bios password. Relatively new motherboard. 8fc8
            latitude 3420
              latitude 3420
                it works, thank you very much!
                  TQVM
                  BIOS WORKING PERFECT
                    Originally posted by SMDFlea View Post
                    The service tag can be found by searching through the bios dump with a hex editor.
                    You know how to do it? You teach me?
                      Re: Dell latitude 3500 admin password
                      can someone help me out ??
                      #FBN5X93-8FC8
                        #FBN5X93-8FC8
                        Upload your bios dump here and someone will do the unlock for you, there is no freely available 8FC8 suffix master password generator.
                        Become a Badcaps supporter
                        Thanks to all supporters.​
                          Hello
                          Need original bios for TGL 203070 , my bios IS note starting the laptop
                          Thank's
                            Originally posted by cesaro View Post
                            Hello
                            Thank's
                            Upload your original bios file
                              Hello there is my bios original
                              thank's
                                thank's
                                It's not a good read, just 35.4 KB is definitely not OK. What programmer you are using, ch341a?
                                  you must open it and the bios IS 33 MB
                                  I'm use EZP2019+
                                    I'm use EZP2019+
                                    Because it's empty, it's full of zeros or FF (doesn't matter it's the same result), that's why it's in KB archived instead of MB as it should be, look at the other archives in the topic.
                                    P.S. You can edit your post instead of posting a new one, if you want to add something.
                                      OK THANK's
                                        OK THANK's
                                        if your bios lost your original dump try this i said if your's lost
                                          Have you read anything of our conversation with Cesaro so far?
                                          It's not lost, he just can't read the bios chip properly, in this case I don't understand how you think it will be able to program it?
                                          And why you are suggesting something without being aware of the problem? Without understanding the consequences, he will try to do what you advise him, and the situation will become much worse.
