Baofeng radio's
    Baofeng radio's
    been fixing up a few.
    here are some notes for others.
    BF-T1 (the tiny one)
    pre-2022 had a lithium pack with a flylead and JST 1.25mm connector.
    the batteries puff up - maybe a bad batch.
    DONT TRUST THE WIRE COLOURS.
    the 2 i worked on had red = 0v, black = +v
    the battery size is: 703450
    general - belt clips
    if you need to replace one, they are not all the same,
    the pitch between the screws varies
    uv-5r - 26mm?
    uv-b5 - 28mm?
    uv-b6 - 28mm?
    uv-6r - 28mm
    bf-t1 - 28mm
    bf888s- 28mm?
    uv-82 - 30mm
    ? = listed by chinese sellers but not personally confirmed.
    Re: Baofeng radio's
    Someone gave me one of these; little handheld. I remember trying to program it with the keypad, it was infuriating. I cheated and got the IO cable and used 'chirp' software.....but the ins and outs are forgotten, it's beena few years ago.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
      Re: Baofeng radio's
      chirp has come a long way recently.
      the keypad programming is not too bad till you want to program offsets between TX & RX.
