I hate to ask this question, because there is no easy answer. Basically, I have a proprietary battery pack. 3 AA batteries sitting on top of 4 AA batteries, glued together. I need a "tab welder" to reproduce this. But I don't really know what settings I would use.
Basically, it is the battery pack from a Scientology E-Meter ("John Travolta Space Cootie Detector"). I got it for journalistic, research and hilarity purposes. Only about 40,000 of these units were made ("Quantum Mark 7") so I suggest a new old stock exact match is out of the question.
I found a couple of 8.4V battery packs online that really might work (3 cells on top of 4 cells). But they are lithium-ion. Will the battery charging circuit inside the meter be able to handle the different chemistry / capacity?
I apologize that I can't give any real info about the charging circuit, except it takes a 5-volt barrel plug from a "wall-wart" AC adapter plugged into the back of the space cootie detector. Any thoughts?
