hi pros! I want to learn about the principle of opening the source of type C charger, because I do not understand it well. for example, I repair the machine using type C,, when the machine has no error, the input current is 20v,, when the fault in the circuit inside the input line is 5v,, if there is no current, the charging pin is faulty,,, so 20v and 5v come out from the charger, what condition is on the type C pin from the main to control the open charge, the current changes like that!
someone explain for me if you understand what i'm saying
Thanks a lot!
Thanks a lot!
