Asus R751L Black Screen (MB: X750LB) bios
    Hello Guys,
    I have a asus r751L with black screen, i'm suspecting a corrupted bios.
    Anyone here with a working Bios Dump ?
    Motherboard is MB: X750LB
    Thank you
    Re: Asus R751L Black Screen (MB: X750LB)
    Anyone with a dump for Asus R751LN Please ?
      read and post old dump i might be able to fix it
      Im Back... sort of...
        Here we go Buddy
        PS: i've found a dump, pc boot's but i don't have picture on hdmi or internal, only vga, i guess that the mobo is "dead" ?
          Thanks to a very kind member of this forum, i was able to activate win 8 with key from my corrupted bios.
          Everything is working, second gpu (nvidia 840M 2gb) is detected and driver is installed, but i can't get a picture on the hdmi or internal display, only the subd15 (VGA) is working with external monitor.
          What it can be the problem ? never see this one before !
            sorry i forgot
            try this
            i hope this is your original dump (non working) or may fix wont help at all
              sorry i forgot
              try this
              Yes, this is the original corrupted dump, was from this dump that a member here extracted the win8 key.
              Do you think that the problem now, is bios related ?
              As laptop is working, all except hdmi and internal display ?
              Cause if it's not bios related, i'm stuck.
                it might be bios
                it might be ME region needs rebuild but in this case i havent done so but i can if needed
                it may also be hardware problem... working on VGA and not working on digital ports like DVI or HDMI (assuming software and driver configured ok) may also indicate problems like VGA needs reflow or so...
                  it might be bios
                  I don't want to abuse of your kindness, but can you redo the bios with ME rebuild, like that i will test with and without.
                  Another wierd thing, when i connect the hdmi out to my monitor, the monitor doesn't detect the hdmi, and switch to dvi or vga.
                  Normaly, even with a laptop turned OFF, when i connect a hdmi to monitor, monitor detects that hdmi is connected but turns off, because there is no signal.
                  But in this case, it doesn't detect anything from the hdmi output.
                    never build me on me9.5 before, noone reported problems
                    anyway here it is
                    do you know history of the laptop? did HDMI work before?
                      thank you
                        Asus R751L doest work
                          Re: Asus R751L Black Screen (MB: X750LB) bios
                          It has been a long, but I had similar case today, X750LB black screen, no CPU voltages, only 3/5V stand by. Last posted here dump did a job, but with code 10 on chipset device, 8086/9c18, no discreete nVidia VGA and random notebook shutdown. So, i`ve updated my broken dump with clean ME 1628 and main update from Asus site, and for now it works fine. May be of someone interest
                            Hi guys, I have a question, I have the same laptop with the same issue starting up nothing on screen, Ive measured board everything looks fine, but as far as I can see somebody tried to flash bios and for 100% its not the original one, can someone give me any advice what now, like I understatnd u need old dump to clean Me but what in this situation if I dont have it ??
                              Post the laptop serial number, your bios backup (even if it is the wrong one) and a picture of the white barcode stickers on the motherboard
                                okay, all I could find in attachments, as you can see sticker looks bad, sorry man but this is how I get this laptop, obviously somebody tried to fix it You can see flux etc but its not a point, If you can help me Ill be gratefull.
                                  Try this one.If it doesn`t boot i don`t think its a bios problem.
                                    Well it didn't boot ,I mean it boots but no picture. Anyway thanks for trying,
