Hi everyone I need this working bios dump file for this model Gateway NV53 (MS2285) I have attached the image of board id please help i need the file very urgent please
Gateway NV53 (MS2285) bios dump
Re: Gateway NV53 (MS2285)
I have the same model laptop turns on but no display and led is present all voltage is present but there is no display I remember before when turn on this gateway laptop i need to press the power button for 5 seconds before turn on. Can someone share a working bios dump file for this model please share
thanks ill tried your bios still the same issue laptop turns on fan spiining for 10 seconds then stop but power led light still presents and when I pressed power button for 10 seconds it turns on with display and then when i turn on again still the same issue fan spiining then pwer led presents but there is no display. I have attached the original bios file can someone please help me fix this problem. thanks in advanceAttached Files
update:after letting turns on without display for 5mins then push power button for ten seconds laptop turns on back to normal but after shutdown cannot turn on again you need to wait 5mins and press power button 10 seconds to turn on back normal can anyone help me please
