Request ZBook 15 G3 Bios Dump
    Re: Request ZBook 15-G3 Bios Dump
    remove the internal battery for any operation in the laptop, so as not to accidentally make any short, you can also remove the bios battery ... post only the contents of the 25Q128FV chip ... do not change any voltage of the programmer ..you have here a program with which others users managed to read the bios chip, if it doesn't work with the one that comes with the programmer..look for a video on the net about how to use the programmer..read the bios chip, make a backup and post ..
    https://www.badcaps.net/forum/showpo...6&postcount=10
      Hi Peste,
      here's the dump. It should have worked (LED on EEPromer lit up, etc.). If you think the dump is defective let me know.
      Thanks for your great help.
      Kind Regards
      Ronald
        Originally posted by RonaldMacDonald View Post
        Hi Peste,
        Kind Regards
        Ronald
        the size is good, but the copy is almost empty..use the HxD program, download here another Zbook 15-G3 bios and with the HxD program see what the bios should look like, and compare with the copy posted by you..make more downloads and comparisons in HxD when you have two equally posted ...
          After 3-4 attempts and reading out BIOS versions, I thought I'd see if the notebook was still running.
          I connected the battery and the CMOS battery and put the bottom back on.
          The notebook booted and landed with 1-2 messages in the BIOS (WITHOUT PASSWORD REQUEST !!).
          I removed all passwords and also did a BIOS downgrade and later upgraded again. The notebook works so far.
          However, the 3rd party BIOS from Intel has somehow been affected.
          I get the following messages before starting Windows 10:
          1.) (a7) me fw downgrade - request mespilock failed
          2.) error sending end of post message to me heci disabled proceeding with boot
          I also cannot install the official Intel Management Engine Driver ("Error: Platform is not supported").
          BIOS downgrade and upgrade run without errors.
          If anyone has any ideas, please let me know.
          Thanks for your help and support in advance.
          Kind Regards
          Ronald
            Need Bios HP ZBook 15 G3 apw50 la-c381p
            Need Bios HP ZBook 15 G3 apw50 la-c381p REV 1B THANKS
              Re: Need Bios HP ZBook 15 G3 apw50 la-c381p
              post the bios backup
                  THANK YOU keeper9779
                    Need Bios main+ec for HP ZBook 15 G3 apw50 la-c381p REV 1B thank you
                      post the backups of the main and EC bios
                        this old backup with problem
                          try..
                            thank you i need ec also its still same issue
                              plz i need APW50 LA-C381P Rev:1b bios i have dump bios
                                heloo
                                I need EC and Bios for HP WORKSTATION ZOOK 15 G3 APW50 LA-C381P REV : 1A
                                thanks
                                  ihave hp zbook g3 cpu xeon mb(apw50 la-c381p rev:1a ) 10-03-2016 ineed bios clr me
                                    post the original bios of the laptop to clean it ...
                                      i want bios ZBOOK-15-G3-APW50-LA-C381P-Rev:1A
                                      i delete my bios and i don't have backup pls help
                                        Re: i want bios ZBOOK-15-G3-APW50-LA-C381P-Rev:1A
                                        Become a Badcaps supporter
                                        Thanks to all supporters.
                                          Originally posted by hoaca388 View Post
                                          what me mean ?
