I have a problem with the bios file Lenovo T450NM-A251. I deleted the original by mistake and tried many files, but the computer turns on and there is no display
Please help me
Please help me
---------------------------------------------------------------------------------------------------------------------------------------------------------- All donations to Badcaps are welcome. Become a Badcaps supporter >>>>>click on this link to donate <<<<< Thanks to all supporters.
all donations are welcome,
>>>>>click on this link to donate via PayPal.<<<<<
Every donation made will go towards server fees and maintenance costs. ----------------------------------------------------------------------------------------------------------------------------------------------------------------------
I can't boot after update due to the process was not successful and can't reboot!
Chip : Winbond 25Q128BV
MTKS Best regards
Your file isn't good, try to read the Chip again correctly.
Also write your device Service Tag.
Motherboard Number should be "LA-C881P" not "LA-C81P".
Thank You for helping, but same blinking 2 times amber, 5 times white. Maybe fault elsewhere, wanted to reflash EC but didn't find EC dump.
Maybe I should change EC chip if it doesn't give EC_Present signal.
Hello @hardware1, was wondering if you can please help me take a look at my 9350 dump and see if it's recoverable? I am sorry I don't know how/where to locate the board number. the ST is GJ2B562. appreciate your help. thank you
You didn't mention your device problem, you can also try the BIOS from post #35 and see if it will works fine or gives you same symptoms.
Thank you for your feedback. The unit powers on briefly and does a 2 amber 2 white blink code repeatedly until it powers itself off. Searching online would suggest this is a BIOS/ROM issue. I tried flashing the ROM from #35 as per your suggestion but the unit is still exhibiting the same behavior so it doesn't appear to be a BIOS problem. Looks like there's a deeper issue with the MOBO, unfortunately, and is beyond my skill level. I do appreciate your help.
