I assume you meam this one as it has a dot on and looks similar to others on yourube!
Ah that would make more sense...it has an arrow, which I assume is number 1 pin. The ref is CN365 or potentially u365. Depending on what label I'm looking at.
Can't quite read what's written on it....looks like a serial number. There is some writing that is slightly obscured. inbond with possibly some missing letters in front of in bond.
Can't get all the numbers / letters. Something like
128FVPQ 1521
E103
41300zy
Oh, forgot to say that since this is wson8 package, you either need to solder wires to the golden pads or unsolder the chip using hot air station. In the first case you don't need the soic8 clip.
I have a heat gun, so probably easier. How do you get back on?
Unsoldering and soldering would be both using a hot air station (do not use a regular paint removing heat gun, it will destroy your board because it usually lacks temperature control).
If you dont have a proper hot air station, just solder wires to the golden pads instead. Will be much less destructive. The down-side is that you might have trouble reading/writing properly when doing it like this.
Please make sure to verify your dump before doing any writing or just read twice and compare files using hex editor.
Thanks. It arrives I'll try solder first. I have a precision soldering iron...I'll try soldering first. Just be the user who don't precision lol
