hp elitebook 8440p
    Re: hp elitebook 8440p
    no display with this also
      Post your old dump.
        i deleted it unfortunatly
          Try this bios .
            thanks alot it works for me
              Re: need bios
              thanks buddy
                Re: need bios
                thank you
                  Thank you bro its work for me too
                    hp elitebook 8440p bios password
                    my friend
                    serial:CZC031549X
                    product:VD484AV
                    system locked
                    thanks
                      Re: hp elitebook 8440p bios password
                      problem solved reinstalled bios
                        Re: need bios elitebook 8440p kcl00 la-4902p
                        thank you
                          thank you
                            kcl00 la-4901p
                            I need Bin for HP Elitebook 8440p. KCLOO LA 4901p Rev 1.0
                              Re: kcl00 la-4901p
                              https://www.laboneinside.com/hp-8440p-bios-bin/
                                thanks
                                    HP EliteBook 8440p
                                    This laptop did not want to turn on.
                                    When i press power button it only flashes battery light.
                                    I tried a minimum of ten different bios dumps,with each bios the laptop lit up,but had no picture.Except one i found on this tread https://www.badcaps.net/forum/showth...light=hp+8440p ,post #13 from SMDFlea.
                                    It turns now on,but now it prints me out : Warning ! Machine is not in comitted state ! After that "product information not valid"... i will post picture here.
                                    I have backup from old dump,if someone can fix old one or modify this new one?
                                    Thank you !
                                      Re: HP EliteBook 8440p
                                      Thank you !
                                      try this with the bios from post # 13 ..
                                      https://www.youtube.com/watch?v=9T57ktw8n3Y
                                        Hello friend !
                                        Mistake on the video is not same as mine,but I definitely tried and it stayed the same.I will post a picture .
                                        Thank you !
                                        Any other suggestions,please ?
                                          Hello friend !
                                          Thank you !
                                          try..
