hp 840 g6 6050A3022501-MB-A01
    Re: HP 840 G6 Bios Password
    So you must dump the 2 bios post it by Peste !
      HP 840 G6 corrupt bios help
      This hp 840 g6 wont boot. I dumped the bios with a ch341a and it seems to be corrupted. Uefitool throws lots of errors.
      Is it repairable?
      motherboard: crescent-6050a3022501-mb-a01
        Re: HP 840 G6 corrupt bios help
        Try to dump again and compare the files.
          I've done the dump many times. it always comes out the same and corrupt. I've not had any other issues like this with other chips, before or after these dumps.
            Try again using NeoProgrammer,AsProgrammer or colibri software, you`ll find them on the forum if you search .Are you using a clip or desoldering
              try..
                Originally posted by peste View Post
                try..
                It won`t work just cleaning the ME as the corruption is through the whole bios with this one.
                  yes..sorry I posted an unfinished bios ... I hope it's ok now ..try..
                    Clip. I was able to reprogram the chip and read it back properly.
                    I also need a dump of the EC chip on the other side of the board.
                      please remove pass from my dump thx so much
                        if it works, enter the DMI information ...
                        https://www.youtube.com/watch?v=9T57ktw8n3Y
                          that is not works i wait meybe somoene unlock my bios dump
                            Hi there guys. i have a problem with my HP 840 G6 how many time i already flash bios but same problem going back bios password
                              OR JUST IF YOU CAN REMOVE PASSWORD BIOS PLEASE CAN help for a brotheR?
                                Hi.
                                Im trying to flash my 840 g6 bios, but my ch341apro (chinesse brand) from amazon cant detect the chip. wich one should i buy compatible with the 25q256jve? (cheapest posible).
                                Ty in advance.
                                  Hp 840 g6 password i unlock it bit gives message
                                  HP 840 G6 with password
                                  i tried with my friend to unlock it but gives me message error
                                  HP Endpoint security controller problem
                                    Re: Hp 840 g6 password i unlock it bit gives message
                                    i tried this two files password removed but gives message on startup
                                    hp endpoint security controller problem
                                      Reset security settings to factory default.
                                        Hello!,
                                        Can you guys help me with Password remove from HP 840 G6?
                                        Thank you,
                                          Originally posted by pcparts350 View Post
                                          Hello!,
                                          Thank you,
                                          try..
