lenovo IdeaPad S145 bios needed
    Re: lenovo IdeaPad S145 bios needed
    Originally posted by bejaoui View Post
    can someone fix my bios dump,, problem is power led blinking and no display, thanks in advanced
    model S145-15IWL
    serial number PF1Q3SH0
    THANK YOU
    Here's your New BIOS, it's a Virgin BIOS from Lenovo with your DMI.
    all donations are welcome,
      Hello
      I have same problem 81MV , blinking white light, no display, all voltages present apart from PL5901
      I try virgin bios from lenovo but it not work, i program with CH341A but still same problem.
      Here is original bios dump if anyone can help.. thank you
        Originally posted by CeeEee4 View Post
        Hello
        if it doesn't work with post #15, you have another problem..
          Good evening, I recently updated the BIOS of my Lenovo S145 15IWL 81MV from the official Lenovo website, but since then, I am only getting BSOD screens when trying to access or install Windows, and the information displayed by the BIOS is incorrect. I no longer have the original BIOS, so I am providing you with the information, and if you could be so kind as to help me recover it. Thank you!
          Code:
          Lenovo Ideapad S145-15IWL
          Model Name: 81MV
          S/N:PF1KE318
          MTM:81MV00U9SP
          FACTORY ID: JVHFC1
          MO:PF9XB96270011
            Code:
            Model Name: 81MV
            S/N:PF1KE318
            MTM:81MV00U9SP
            FACTORY ID: JVHFC1
            MO:PF9XB96270011
            Why you don't have the Original BIOS? We need anything from your Chip even if it's corrupted. That will help us to confirm your BIOS and transfer your DMI.
              Unfortunately, I don't have the original BIOS. I performed a complete wipe after several attempts, and used a dump that I obtained here with the similar hardware specs. It starts and runs fine with Ubuntu 22, but when I try to install Windows, I get numerous BSODs except in safe mode. I suspect it's because of the BIOS. Is there any way to obtain it, or should I give up on it? Thank you for your help.
                Try the file in Post #301, it's a Virgin BIOS for your Device.
                  Someone Help pls blinking white led dont know how to copy dmi heres the original corrupted bios
                  Lenovo Ideapad S145-14IWL
                  Model Name: 81MU
                    Model Name: 81MU
                    Heres the file
                      Heres the file
                      try bios post#97..
                      https://www.badcaps.net/forum/showth...ht=81MU&page=5
                        Unfortunately it doesn't work still blinking led light I'm using a ch341a programmer btw and neoprogrammer
                          Originally posted by peste View Post
                          Unfortunately it still doesn't work still blinking led, I'm using a ch341a programmer btw and a neoprogrammer software
                            On the other programmer it always says "Chip Main Memory with the contents are in disagreement, and when i checked it with HxD and compare it it's not identical with the file i write and the file on the chip
                              Also when I use flashrom on ubuntu and do md5sum checksum after programming the results are the same on chip contents and the file I was flashing
                                ...btw and a neoprogrammer software
                                Which version?
                                Clamp, or wires, or adapter, or ... is used to read the chip?
                                Become a Badcaps supporter
                                Thanks to all supporters.​
                                  Originally posted by Vesko356 View Post
                                  Which version?
                                  I used ch341a usb programmer and desoldered the chip from the mb and soldered it to the programmer
                                    How about the version of the NeoProgrammer?
                                      I have able to flash the file @peste give and the laptop works, just curious why the led light keeps blinking
                                        I change my software to Ch341a V1.18 the laptop turns on now using the file peste told me just didn't it works because the led keeps blinking i thought its not working but when I leave it on for about 30secs. the laptop boots. The only problem now is the led light keep blinking like it was before.
                                          It's working now, I just leave it to charge then after turning on the blinking light is now steady thanks to all of you kudos.
