Toshiba protege password
    Hi here toshiba protege z30-b-10k have password some one can help to remove password please
    Re: Toshiba protege password
    The password will be stored in the SMSC MEC chip,it can`t be programmed as JTAG access is blocked. The only way to remove it is by challenge-response code or by using another chip from a donor board that has no pass.
      many guys unlocked with the method bypass by modding bios dump and not share
        There's no way to "modding the bios" with any "method" leading to clear the password on this particular model. SMDFlea wrote it clearly for you what is the situation, and he certainly knew a lot more than you about it.
        Become a Badcaps supporter
        Thanks to all supporters.​
          hoax...
            For information ... all these models are unlocked only through the response code:
            Portege (A30, A600, M100, M200, M300, M400, M700, M750, M780, R30-A, R100, R200, R400, R500, R600, R700, R830, R930, S100, Z830, Z930, Z10T-A, Z20T-B, Z30T-A/B/C, X20W-D, X30-D)
            Qosmio (F20, F30, F60, F750, G10, G20, G30, G40, G50)
            Satellite (M30, R10, R20, R630, R830, R840, R850, R930, Z930, U200, U920, Z30-A)
            Satellite Pro (A30-D, A40-D, A50, A120, M10, M30, R40-D, R50-B/C/D, R840, R850, R950, S200, S300, S300L, S500, U200)
            Tecra (A3X, A9, A10, A11, A40-D, A50, A50-D, C50-C, M1, M2, M3, M4, M5, M7, M9, M10, M11, R840, R850, R940, R950, S3, S4, S5, S10, S11, X40-D, W50- A, Z40T-A/B/C, Z50-A/B/C/D), WT310, Kira, Libretto (U100, W100)
              he tell only and never share anything
                Thanks for you all here i have serial and chalange code
                pc sreial=yf029393h
                chalange code = wpmhl-cpmqv-nfx45-2153e-jll0
                response code=?????
                I need response code some one can help me to find it
                  chalange code=WPMHL-CPMQV-NFX45-2153E-JLLB0
                    For Portege R30-A how can I unlock the bios password?
                      Read post # 2 and https://www.badcaps.net/forum/showthread.php?t=41797
                        PC serial no. 9B164431H
                        CHALLANGE CODE H5LYK-3XD79-KFCTG-B2UJ4-8V36G
                        can kindly provide me the response code for this thnks so much
                          pc sreial=3E017350H
                          chalange code = 7U6L6-8Q93D-N00DJ-H2JB1-EANPR
                          response code=?????
                          HELP ME PLAESE.
                            pc serial no. = 5A015044H
                            Challenge Code = ER92C-G2415-HLC58-CRABG-NW00E
                            Response Code = ???
                            please help.
                              I need response code some one can help me to find it help me please.
                              pc serial no. = 2E128937H
                              Challenge Code = R849Q-XBEA9-XFN52-1RGYC-FAGON
                              Response Code = ???
                                Kindly help with the response Code:
                                PC SERIAL no=YA172500H
                                CHALLENGE CODE=51K7P-3MBY2-3Y5GC-Y5LK3-6B2DV
                                RESPONSE CODE=????
                                  RESPONSE CODE=????
                                  Response Code = XX7P4-UU967-J0YTP-YBMER-41TXP
                                    can you help me ؟
                                    Thanks in advance
                                    pc serial no = 16032907H
                                    challeng code = R1YFB-G31GU-BBLHL-XY46L-JM03X
                                    RESPONSE CODE=????
                                      Originally posted by ibrahim03 View Post
                                      can you help me ؟
                                      Thanks in advance
                                      RESPONSE CODE=????
                                      Response Code = KCVX8-0P019-R6CA3-BX6C0-79YHG
                                        not certified
                                        press any key to shut down system
                                        Then it is changed to
                                        challeng code = 20YU4-36NAC-ELPCL-078AN-YWUDG
                                        Note: What is in the challeng code is zero and not O
