Need bios hp fpw50 la-h323p rev: 1.0
Re: Need bios hp fpw50 la-h323p rev: 1.0
Originally posted by Microm View PostHi, i have a hp 15-dw1060la the caps lock is blinking 3 slow and 2 fast
old Bios
Serial Number: CND111F4QG.Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
its my hp laptop old bios, S/n. CND9241NP7
anyone help me. please rebuild this bios
no display problem
MB MODEL LA-h323pAttached FilesLast edited by faisalhabib; 05-08-2023, 04:25 AM.
Hi everyone,
i have this hp 15-dw0120nl (i7-8th) with la-h323p rev 1.0 2019-01-04 motherboard, issue: blinking capslock 5 times slow and 3 fast.
I tryed flashing several dump files in this post but none working.
I attach my backup file, can someone help me to clean this dump?
Thanks very wellAttached Files
Thanks very wellDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Originally posted by bomber8596 View Post2nd reading attached
thks
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..
thks
there are differences between what you sent the first time and the second time..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Originally posted by bomber8596 View PostThird reading
Use BID 085EF bios.
Transfer DMI + Windows key from your dump to the new one using offsets:
320000 - 321FFF
HP Notebook - 15-dw0120nl bios F.43 Rev.A----------------------------------------------------------------------------------------------------------------------------------------------------------
Hello.
Can i get some assistance too please. I have a Hp 15-DW1014ni that has the 3 long 2 short capslock light. I followed the bios cleaning steps posted elsewhere on badcaps but wasn't 100% successful due to bios encryption and i'm still on the 3 long 2 short code.
Edit: Just incase it's missed the motherboard is the LA-H325P with Celeron N4020 cpu.
Thanks in advance.Attached FilesLast edited by odtech; 08-09-2023, 09:30 PM.
Thanks in advance.
https://www.badcaps.net/forum/showpo...45&postcount=7
[Guide] How to extract ready for programming dump from HP update executable file
https://www.badcaps.net/forum/showthread.php?p=1259537
Find your BID version and use the offsets shown in post #53 to transfer DMI + Windows key from your dump to the new one.
Originally posted by Vesko356 View Post6. Extracting BIOS/EC firmware from update packages
I will try this tonight. I did start on this route but then i got stuck with locating my bios file so I went off on the cleaning the bios route instead which didn't work.
Originally posted by Vesko356 View PostThere's no need to perform cleaning the ME Firmware in the original dump - it'll be much better to use a virgin dump from the manufacturer support site. You already have it extracted in post #53, as I said just find the BID number in your original dump to know which one of the posted files you need to use, transfer the DMI and Windows key and you're good to go.
In the ME cleaning guide they spoke about encryption keys stored in offset 2000 to 4000 that needed to be copied because my bios is apparently encrypted. Should i copy those too or not necessary?
Originally posted by odtech View PostI tried by copying the offsets in post 53 from the original bios to a virgin bios but it didn't work. Caps lock still flashing 3 2.
Originally posted by SMDFlea View PostThe HP signed SMIP is already in the virgin bios. You only need to mess around if you`re cleaning your own bios.As vesko said,its easier just to use the virgin bios. 3.2 blinks is a ram fault, check for loose ram slot pins and resolder them. If that doesn`t work its usually some other hardware problem.
The reason I'm sort of convinced it is the bios is the fact that the laptop is basically brand new. It's a elderly man that bought it but didn't finish migrating to the laptop from his desktop then stored the laptop for a few months. When he fired it up it was dead as a door nail. So i'm thinking frozen bios but having no luck yet. I'm about to toss it though because it's not worth the time it being the bottom of the barrel basic celeron machine.
