Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Thread Tools Display Modes
Old 02-28-2020, 12:22 PM   #1
ElectronicsOverhaul
City & State: Chesapeake, VA
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Professional Tech
Default Identify PS4 HDMI SMD
Another individual or tech horribly replaced the HDMI port. Customer pushed the whole inner wafer in knocking out three components. I have the diodes already in stock and have replaced hundreds of these ports. Can you label component that's identified by 16? I assume it's the same as the one directly below it. This is for CUH-1115A which probably the same as CUH-1005A.
ElectronicsOverhaul is offline   Reply With Quote
Old 03-12-2020, 09:47 AM   #2
ElectronicsOverhaul
My Country: USA
Default Re: Identify PS4 HDMI SMD
Never mind, grabbed them from a BLoD board.
Old 03-23-2020, 06:10 PM   #3
ngth82
City & State: Vancouver, WA
My Country: USA
I'm a: Hardcore Geek
Likely just a pull up resistor.
Did you by any chance check the resistance of that location when you grabbed it from a BLOD system?
__________________
-Thomas
I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
ngth82 is offline   Reply With Quote
Old 03-24-2020, 09:42 PM   #4
ElectronicsOverhaul
My Country: USA
I did not check them, probably should have. They were easy to transfer with hot tweezers though.
Old 05-10-2020, 11:00 PM   #5
ElectronicsOverhaul
My Country: USA
A video game shop owner brought me a botched PS4 that someone tried to replace the HDMI port with the resistors out of placement from too much heat and a missing zener diode.
The two light blue/gray resistors on a CUH-1115A have the following attributes:
2k ohms
1 x 0.5mm or 0402 (1005 metric)
Height: 0.35mm
Power: either 1/16W or 1/10W, higher probably better
I've replaced several zener diodes with P/N VDZT2R5.6B on PS4s, and they've always worked. They're close to the port on the CUH-1215A model, and sometimes customers push the ports inward knocking off the diode. Saw two diodes blow along with an HDMI encoder IC once.
Old 03-27-2020, 05:55 PM   #6
ngth82
My Country: USA
Cool. Just to follow up --- is the console good to go then? Did you fix it?
Looking at the HDMI pinout and assuming the color coding is correct. This is pin 16 -- the DDC Data -- it's an I2C bus dataline. The drivers are ope-drain and need a pull up to function.
Old 03-28-2020, 07:27 PM   #7
ElectronicsOverhaul
My Country: USA
Yes, it already has been repaired.
Old 11-15-2020, 03:20 PM   #8
Christian0734
City & State: Montpellier
My Country: France
Line Voltage: 220v
Hello everyone
I posted a new topic, I have almost the same concern
Christian0734 is offline   Reply With Quote
Old 12-04-2021, 07:55 AM   #9
BeertjeBas
City & State: Almelo
My Country: Nederland
I'm a: Knowledge Seeker
Can anyone tell me what type or value the diode represents in the yellow sqaure.. Its missing and i have no donorboard .
Thanks in advance
Gerard,
BeertjeBas is offline   Reply With Quote
Old 01-18-2022, 05:20 PM   #10
Mechengr103
City & State: Greenville South Carolina
My Country: USA
Can anyone tell me what the resistor or capacitor is label 18 in this image? I've seen it described as a resistor and others say it's a capacitor. I am repairing a board for a friend that it was missing. So I don't have a donor board to look it up or transfer it from.
Mechengr103 is offline   Reply With Quote
Old 01-20-2022, 08:41 PM   #11
momaka
master hoarder
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
Quote:
It looks like a ceramic capacitors. According to image in first post, it connects to the pink trace, which appears to be some kind of a power rail (5V?) My guess would be, that ceramic cap is there for just extra noise filtering on the power rail, and the HDMI port might work fine without it. But if you really wanted to have something there, I think 100-470 nF cap will probably do the trick. You can find 100 nF caps on the PCI-E lanes of discrete computer GPUs.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
