Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Thread Tools Display Modes
Old 11-12-2021, 02:42 PM   #21
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
Default Re: Motor control board repair
Quote:
Originally Posted by cyclones View Post
It looks like the -15V goes back to SR3 and the voltage regulator that doesn't get warm, AVR2. From looking at the trace lines and from the meter, it seems like the AVR2 is in parallel. SR3 has a + and - and two middle pins that go to the AC input, so it seems like a rectifier bridge, but I don't know what the SR3 designation could mean. Any ideas?
Are you getting a/c voltage to SR3? It is likely a bridge rectifier, why it is labeled SR3, who knows.
If you are not getting any a/c to the bridge, check the resistance of the traces and the power supply winding that supplies that circuit.
What is the part number on SR3?
R_J is online now   Reply With Quote
Old 11-12-2021, 07:45 PM   #22
cyclones
City & State: Ames Iowa USA
Line Voltage: 120VAC 60Hz
Is it going to be safe to power up the board with 120VAC? That's about 10% higher than the 107V at the machine. I assume any voltage regulators should be able to handle that but just wanted to check first since I've not dealt with something that is expecting 107V.
cyclones is offline   Reply With Quote
Old 11-12-2021, 10:40 PM   #23
sam_sam_sam
City & State: Some times Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
I'm a: Knowledge Seeker
If this machine has a step down transformer that supply’s power to this board look and see if it says 110 volt or not because if does do you know if your facility has a hot leg if it does then you might have the transformer on the wrong set of legs because if the step down transformer says 110 to 120 volts output
Because I has this happen to me one time and when I switch the legs to a certain way I got the correct voltage however do not change the machine main power supply legs unless you do NOT have any other motors on this machine because your rotation might be wrong
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 11-13-2021, 08:35 PM   #24
R_J
City & State: ☻
My Country: Canada
It should be ok, but you could also just check the resistance like I said. The transformer winding should connect directly to the ~~ connections on the bridge rectifier.
Old 11-17-2021, 10:24 AM   #25
cyclones
Yes, it does. I measured half an ohm (0.5 ohms) resistance on the traces. The letters and numbers on the apparent BR are LBA 63.
Old 11-17-2021, 11:26 AM   #26
R_J
City & State: ☻
My Country: Canada
I suspect you have the -15 volts, It was only missing because the main transformer was not being used.
Old 11-17-2021, 05:47 PM   #27
cyclones
I tried it in the machine with everything connected and the -15V was missing.
Old 11-17-2021, 06:30 PM   #28
cyclones
I just connected my DC power supply to the middle pins of SR3 (where the AC is supposed to go) and supplied 20 volts and the -15V rail comes up.
Old 11-17-2021, 06:33 PM   #29
R_J
City & State: ☻
My Country: Canada
That proves the bridge rectifier and the rest of the -15v circuit is ok. The fault is then with either the transformer not supplying the a/c to the bridge or there is a break (or small fuse) between the transformer and the bridge rectifier.
I hope the transformer was NOT connected when you applied the 20 volts to the bridge? if it was that may have opened the winding on the transformer as the winding would be a very low resistance to the 20vdc.
Old 11-17-2021, 07:22 PM   #30
cyclones
Well, I found the problem causing no -15V. It's the connector. It's not making good contact, but I'm sure I accidentally bent that pin when I was originally trying to measure transformer output voltages. So I'll have to either fix that or replace the connector. I've seen this type before so I assume I can find one.
So now I guess I power it up on 120V with attention to that connector and see what I get.
Old 11-20-2021, 10:53 AM   #31
sam_sam_sam
My Country: USA
Let us know if you were able to fix this board issue or not
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
