Sony KDL-46Z4100 another TCON problem?
  • apolodor2014
    • Mar 2014
    • US
    #41
    Re: Sony KDL-46Z4100 another TCON problem?
    Hi All
    As is see postings are from 2013, but i thought to give it a shot . I have the same problem with this model Sony KDL 46 Z4100. Vertical colors lines . That's it. Should i look for this chimera of T-CON board ? Just can't afford a new TV now and i'm using a LG 32 inch as a backup...ouch .
    Any feedback is appreciated .
    Thank You
      To me, that looks like a bad panel.
      • Davheel
        • Mar 2013
        • 8
        I have a KDL-46EX1 with the same issue of vertical color lines, the T-con board has Sony part no. A1567986A label 1-878-182-11, cannot find a replacement anywhere, just wonder is another board with same label 1-878-182-11 but different Sony part no compatiable?
        • truep
          • Aug 2010
          • 373
          Do the lines move around with the old TCON? they did on the sony where I replaced the main board. What is the number on the sticker on the TCON, I'll see if I cand the one I bought before the main board.
          • Davheel
            • Mar 2013
            • 8
            Yes the vertical color lines move around and when you change channels or press menu on the remote.
            The number on the TCON is 1-878-182-11 A1567986A YX089700A
            The number on the main board is A1726506A 7050778 16411992
            • Steamy777
              • Oct 2013
              • 8
              Why does the thread end here I have the same problem as chuck not dave my tv look the same and the lines move when on cable tv was it the main board or tcon???
              • bigbrihh
                • Aug 2014
                • 3
                hey everyone, very new to the forum, but it looks like I have found the right place to get my recently purchased and very used kdl-46z4100 back into working order. All is great with the TV but it looks like the whiteness in the video color is gone and people look orange and and the overall picture has a orange film to it. Is this the tcon board or the gamma IC (as15-f) on the board that is causing the discoloration or a problem with the back light inverter? from what ive read this issue is from the gamma IC. I can post a picture later when I get back home. I got it for $250 which I am really happy about but would like to see if I can fix the issue with a $2 chip vs a $130 board.
                • oldguy70
                  • Sep 2014
                  • 3
                  KDL-40VL160 also uses A1564648A tcon. If i connect both ribbon connectors, my tv will come on with dark blue screen, then shut off after about 10 secs.
                  If I disconnect one ribbon connector, the tv will come on with half white display and half normal display. This tells me there is a short on the side with the white display.
                  I did resistance checks comparing readings of one ribbon connector to the other. and found a shorted pin on the bad side ribbon connector. When I disconnect the ribbon cable on the bad side and read resistance, the short is on the tcon side and not the panel side of the ribbon cable.
                  I know this is long, but it is one way of isolating one half of the tcon and verifying that the tcon is definitely bad.
                    The shorts are probably the TFT IC drivers on the flexible PCB between the LCD GLASS panel and the long PCB where the flexible PCBs are bonded to.
                    • Davheel
                      • Mar 2013
                      • 8
                      Hi everyone, an update to my vertical strip display problem, finally I obtained a replacement T-con part no. A1567986A label 1-878-182-11, put it in but the issue remains, so it is down to the main board or bad panel.
                      • Davheel
                        • Mar 2013
                        • 8
                        Hi, I have attached some images of my TV display, the vertical stripes moves around, does this appears to be a bad panel? Any feedback is appreciated!
                        Thanks.
                        • blouis79
                          • Jun 2009
                          • 5
                          #52
                          Worth reading this document "Sony lcd tv tcon troubleshooting and replacement" - Google and there are multiple sources.
                          There is a similar but different document called "Sony tcon training manual". It shows examples of tab bond failures too.
                            Like this?
                            https://www.badcaps.net/forum/showpo...4&postcount=12
                            • blouis79
                              • Jun 2009
                              • 5
                              #54
                              Originally posted by budm
                              Yes. That's probably where I got them from.
                              • Davheel
                                • Mar 2013
                                • 8
                                Have already swap T-CON, Main board, cable from Main board to T-CON, so the only thing left is panel, unless someone have other ideas, thanks.
                                • rpmillenium
                                  • Jul 2015
                                  • usa
                                  #56
                                  Hey guys, I have this issue with my KDL-46z4100:
                                  When I turn it on the image is white with a strips, and after a minute turns completely white.
                                  Do you think it's a bad TCON? Or a bad panel?
                                  Thanks in advance!
                                  • xredhawk
                                    • Jul 2011
                                    • 103
                                    #57
                                    i have a sony with vertical lines with a burning hot gamma chip
                                    • husky601
                                      • Apr 2015
                                      • 36
                                      Did someone here was able to fix it or can confirm this is the panel it self? Thanks!!
                                      • freakaftr8
                                        • Oct 2012
                                        • 3743
                                        I've dealt with this board a few times now. I have successfully repaired quite a few but they are no walk in the park. On those four dc/dc converter outputs you should be receiving 1.0 volts for the core voltage 3.3 volts 12 volts and 2.2 volts or something to that liking. You can test these at the outputs after each of the 4 black coils. If one DC converter voltage regulator goes bad it will drag down one of the voltages. In order to repair this you need to replace all 8 DC converters including the converter drivers on the opposite side of the board. There will be two of these one for each bank of 4. Along with that replace the 4 diodes. This should get you up and going if you're missing any voltages.
                                        Also noise in one of the stage outputs cause all sorts of problems. Mostly the 1.0v for the cpu and the 3.3v for ddr ram.
                                        • henryczek
                                          • Nov 2016
                                          • Poland
                                          #60
                                          Hi, what you mean "opposite side of the board"? Does it mean the bottom side?
                                          What drives those voltage regulators. Thanks.
                                          • Daren87
                                            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                            by Daren87
                                            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                            08-13-2023, 03:25 PM
                                          • thelankanguy
                                            Sony KD-55X9000F TCON Issue
                                            by thelankanguy
                                            The TV shows a black screen with no image.
                                            TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                            Later both ribbons were disconnected and TCON voltages were tested.
                                            12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                            There is also a short to ground in this circled inductor.
                                            Is this a TCON issue or something else ?...
                                            12-13-2024, 12:27 AM
                                          • bbrain
                                            Sony KD-55AG9 TCON?
                                            by bbrain
                                            I have this problem with my Sony 55' AG9.
                                            It flashes 4x.
                                            I have found the service manual, and seems it is the TCON.
                                            Before I buy a TCON can someone check the vid?
                                            Thanks in advance!...
                                            09-19-2024, 10:50 AM
                                          • rimwall
                                            Sony KD-65x8500b - bad Tcon or panel?
                                            by rimwall
                                            Hi, hoping for some views on this one which I've not come across before. The TV generates an image that has 12 noticeable bands across it. The image is still there and accurate, but the colour (or perhaps the brightness) changes gradually across each band which creates a noticeable 'step change' at the edge of each band. Given it's a 4K TV with 2160 rows of pixels, I'm guessing the 12 bands correspond to 12 gate drivers of 180 rows each. If this guess is right, then perhaps:
                                            a) all the gate drivers are malfunctioning the same way (which seems unlikely), or
                                            b) the Tcon board is malfunctioning,...
                                            10-24-2023, 07:58 PM
                                          • x_orange90_x
                                            TCL 50S535 bad tcon or panel issue?
                                            by x_orange90_x
                                            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                            03-29-2025, 11:02 PM
