Dell Latitude e6510 Boots Once in UEFI
    Ok, really strange problem here. I have a laptop, a dell latitude e6510. When I go into the bios, I can delete all the efi boot options, replace one, and have it boot. When I shut down the laptop, it will not boot again until I go in, remove the efi boot options, replace it and save.
    For some reason, the bios screens also seem a bit on the slow side, I can see the pages draw down the screen. I have tried all manner of setting the efi nvram options from linux and windows, nothing works.
    Anyone have any ideas of what to try?
    Thanks!
    Edit: I just replaced the fan and put new thermal compound on the CPU, I had suspected it was an overheating issue, but it hasn't changed anything.
    Re: Dell Latitude e6510 Boots Once in UEFI
    Have you tried updating the BIOS?
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
      Yeah, I was considering that, but was concerned that if I did so, it might just die completely.
      Do the bios chips get fatigued? Or is corruption more likely? I suspect the last windows update did something...
        Likely just corruption, read: bit rot.
        I had problems with my E6520 refusing to reboot properly. I upgraded the BIOS and the problems went away.
        You'll need to use FreeDOS in clean boot mode (spam F5 on boot) to run the BIOS update.
        sigpic
          Thank you. I'm going to try this once I'm at a place where I can reboot and be without my computer for a while should things go wrong... I have a spare small partition, I might just throw freedos on there for grins.
