Go Back   Badcaps Forums > Welcome to the Badcaps.net Tech Forum! > Frequently Asked Questions (No Posting)
Old 08-12-2007, 10:00 PM   #1
davmax
davmax's Avatar
City & State: Perth Western Australia
Default Capacitor ESR
Capacitor ESR is often raised as an issue. The following link gives a good explanation of ESR and related capacitor characteristics.
http://xtronics.com/reference/esr.htm
Gigabyte EP45-DS3L Ultra Reliable (Power saver)
Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
160Gb WD SATAII Server grade
Nvidia 8500GT 256Mb
160Gb WD eSATAII Server grade for backup.
Samsung 18x DVD writer
Pioneer 16x DVD writer + 6x Dual layer
33 way card reader
Windows XP Pro SP3
Thermaltake Matrix case with 430W Silent Power
17" Benq FP737s LCD monitor
HP Officejet Pro K5300 with refillable tanks
davmax is offline   Reply With Quote
Old 12-09-2007, 03:40 AM   #2
redassa
Default Re: Capacitor ESR
I Wanted To Ask About The Relation Between ESR For Caps & The Power Sustained & If Leakage Current Is Related To That ESR?
Thanx
redassa is offline   Reply With Quote
Old 07-02-2013, 06:43 PM   #3
bazatheman
City & State: washington
My Country: uk
The first thing I thought about after reading a few posts on here was ... I must invest in a ESR meter and understanding the characteristics of capacitors is a good learning investment .
Know thy enemy... with all the bad caps out there causing untold damage to our electronics I will be working on my knowledge base... Cheers.. Barry
bazatheman is offline   Reply With Quote
Old 11-13-2014, 07:34 PM   #4
blouis79
I got the impression ESR is important and that caps can test OK on other paremeters but if ESR is wrong, they won't work.
I read that Bob Parker seems to have credit for inventing ESR meters. Has lots of info on ESR meter kits.
http://members.ozemail.com.au/~bobpar/esrmeter.htm
Looking around at various ESR meter kits, I found Peak Electronics UK - fully built ESR meters. I got several of their meters and have found them really useful, since they measure a load of thing my Fluke multimeter won't do. I bought direct from Peak for a lot less money than I could find locally.
http://www.peakelec.co.uk/acatalog/jz_instruments.html
blouis79 is offline   Reply With Quote
Old 01-27-2015, 08:06 AM   #5
Hop Tzop
City & State: Mioveni
My Country: Romania
Hi everyone,
I am new and I can't start a new thread. I'm looking in changing some electrolytic capacitors on a Gigabyte P35-S3G, near ram. I've already replaced 2 of them, but two others gone bad and I'm thinking on replacing all of them with polymer capacitors. Then searching on the internet I came on ESR. I've read that they should have different capacity if you replace electrolytic ones with polymer.
My actual capacitors are 6.3V, 1000uF and I've found polymer capacitors with the same ratings, 6.3V, 1000uF and ESR 7 mOhms. Would that be good for my motherboard?
Description of the polymer capacitor.
Code:
Manufacturer: Nichicon
Product Category: Aluminum Organic Polymer Capacitors
RoHS: RoHS Compliant Details
Product Type: Can
Capacitance: 1000 uF
Voltage Rating DC: 6.3 V
Tolerance: 20 %
ESR: 7 mOhms
Termination Style: Radial
Minimum Operating Temperature: - 55 C
Maximum Operating Temperature: + 105 C
Case Length: 12.5 mm
Case Diameter: 10 mm
Lead Spacing: 5 mm
Operating Temperature Range: - 55 C to + 105 C
Packaging: Bulk
Product: Organic Polymer Aluminum - Radial Capacitors
Series: R7
Tradename: FPCAP
Hop Tzop is offline   Reply With Quote
Old 08-26-2016, 07:32 PM   #6
Sai Peregrinus
City & State: Hartford, CT
The following site is a good resource of ways to measure ESR, from manual methods with oscilloscope & function gen through DIY kits to commercial devices. Don't try to do it in-circuit, at least lift one leg of the capacitor under test.
Sai Peregrinus is offline   Reply With Quote
Old 08-26-2016, 07:34 PM   #7
Sai Peregrinus
http://kripton2035.free.fr/esr-repository.html
It would have helped to include the URL, wouldn't it?
Old 01-09-2022, 05:35 AM   #8
Behemot
Behemot's Avatar
City & State: Prague, 50°4'52.22"N, 14°23'30.45"E
My Country: CZ
Line Voltage: 230 V/50 Hz
most of the instruments there are obsolete (like that ESR Micro v4.0 leading to who knows what website, I resell v5.0S/+ for like 3 years now) and there is no reason to unsolder every cap, that would be insane nightmare to do pretty much anything
Behemot is offline   Reply With Quote
Badcaps.net Technical Forums © 2003 - 2022
