Thread Tools | Display Modes |
#1 |
City & State: Alberta
My Country: Canada
![]() New Panasonic FC series cap I got from Digikey, tossed it in the parts bin a year ago. Today, I saw the leads have green corrosion on both leads at the bung?!
It this leaking, yet never used? EEUFC1C392 The datasheet says: "This Series is no longer available for purchase in the country of Japan." Gosh, is FC's quality has gone to china? |
#2 |
City & State: Rockford, IL
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Knowledge Seeker
![]() I've seen capacitors leak white, yellow, brown and black colored electrolyte but never green.
#3 | |
master hoarder
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
![]() Quote:
I've seen this quite a bit on old Nichicon PR series capacitors, and those tend to leak out of their bungs quite frequently after some years. I've also seen this on some new Nichicon PM caps. Possibly. What hasn't, these days? ![]() |
#4 |
HC Overclocker
City & State: Singapore
My Country: Singapore
Line Voltage: 240VAC 50Hz
![]() yupp, that greenish colour looks exactly like copper oxide. looks like the copper of the cap leads has somehow become oxidised and it seemed to originate from inside the cap. if it were due to oxidation/corrosion due to environmental storage conditions, the oxidation would be seen randomly around and all over the leads but it seems to be occuring coming out from the leads inside the cap, so something went wrong inside the cap.
if this happened on only one cap, i'd just attribute it to being a bum/lemon cap that escaped qc at the factory. shit happens... |
#5 |
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
![]() the bung hardens over time - maybe because of an interaction with the electrolyte,
maybe because of the humidity or temperature of the enviroment. i have seen lots of leaked FC's and mentioned it atleast a few times. always around the bung, and they are never domed. i have not seen the same issue on FM or FK. |
#6 |
My Country: Canada
![]() The bung hasn't even been through reflow or any soldering.
It's a high-end part with AEC-Q200, 5,000hrs 105°C and last time I saw this was on 30 year old Spragues. I emailed Panasonic to see if they will comment. Panasonic FC series has been my go-to for replacements in vintage gear. Not SMPS where low ESR is essential, but instead for audio gear. I'll have to find something alternate I guess. |
#7 |
City & State: CA.
My Country: USA.
Line Voltage: 120-125VAC 60Hz.
![]() What does the datecode on the FC say? I know how to decode Panasonic’s date decoding format and as do other members here. I guess it can’t be that old - probably less than a decade old. Momaka’s Nichicon PMs, going by the original revelation he posted, leaked around four years ago now (after only five years in storage judging by their datecodes). That Panasonic FC would be exhibiting this type of behavior, along with Nichicon PM, is equally confounding. I only know of two types of capacitor “plagues” which caused Japanese electrolytics to leak from the bung with no notable hydrogen gas production - the quaternary ammonium salt plague from the late 80s / early 90s (which should no longer be an issue) and a separate problem from that time frame and a bit later with 85şC capacitors and SMD capacitors having problems with rubber bung deterioration (and leakage thereafter).
It would be a pity if Panasonic FC ended up having this problem. I know a number of members have used them here in their repairs before, and it would suck if this comes back to bite them. |
#8 |
My Country: Canada
![]() 6201MC, DF is 0.25, ESR is good.
#9 |
City & State: CA.
My Country: USA.
![]() Looks like it was made in either February of 2006 or 2016. I’d hope the former because only new cheapos should leak after 3~4 years of sitting in storage (13~14 years would be more reasonable although still disappointing)...
#10 | ||
master hoarder
My Country: U.S.A.
![]() Quote:
FC is also one of the few series rated for automotive applications. And we all know how "not-so-easy" the environment inside a car can be on components. So I'm really hoping this is just an isolated case or maybe just a bad batch/run of the week at most. Quote:
What's interesting is that on these caps, the ESR and capacitance were still in spec the last time I checked them a year ago (or was it two now? ![]() Last edited by momaka; 01-20-2020 at 05:56 PM.. |
#11 |
City & State: North Springfield, Vermont
My Country: USA
Line Voltage: 118-127V 59-63.5 Hz-> actualizo: pérdido de voltaje
![]() Is that the Panasonic (if not still Matsushita) version of KZG?! Yikes!
__________________
ASRock B550 PG Velocita Ryzen 5 "Vermeer" 5600X 32 GB G.Skill Trident Z Neo F4-3600C18D-32GTZN Sapphire Nitro+ Radeon RX 6750 XT eVGA Supernova G3 750W Western Digital Black SN850 1TB NVMe SSD "ˇMe encanta "Me Encanta o Enlistarlo con Hilary Farr"!" -mí mismo "There's nothing more unattractive than a chick smoking a cigarette" -Topcat "Today's lesson in pissivity comes in the form of a ziplock baggie full of GPU extension brackets & hardware that for the last ~3 years have been on my bench, always in my way, getting moved around constantly....and yesterday I found myself in need of them....and the bastards are now nowhere to be found! Motherfracker!!" -Topcat "did I see a chair fly? I think I did! Time for popcorn!" -ratdude747 |
#12 | ||
City & State: CA.
My Country: USA.
![]() Quote:
Quote:
Unlikely. Stj said they’re (the FCs) never domed, only that they leak from the bung. The failure mode is different and I’d guess not as fast. Probably no outgassing either. |
#13 |
![]() all the bad ones had been in use atleast 10years
#14 |
My Country: Canada
![]() 1st response from Panasonic rep:
"... I would not use a part that had corrosion on the leads. It could effect the performance. Sounds like moisture got into the packaging. Please let me know if you have any questions." I won't store them in the rain lol ![]() I guess FC's have some seal problem if they are leaking even before being used. Sad. |
#15 |
![]() one thing i'v noticed with leaking caps regardless of make - it's usually the same leg.
i think the negative. could it be some type of electrolysis drawing the fluid to that side? |
#16 |
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
![]() had a power supply for an apple 2e i repaired 10 years ago come back to me .
all the fc were leaking from the bung. unit runs 24/7/365 and cool. this is not good! |
#17 |
HC Overclocker
![]() damn and i wanted to get a shitload of 100uf 16v panny fc for recapping audio decoupling caps with better ones. guess i'll remove the item from my shopping cart. any other recommendation for ultra low leakage current gbl based caps for audio decoupliong?
#18 |
My Country: U.S.A!
![]() note that they lasted over 87000 hours.
thats continuous. sounded worse than it was. but leaking and corroding unused parts? not good! |
#19 | |
City & State: CA.
My Country: USA.
![]() Quote:
#20 |
![]() audio decoupling, i like rubycon YXF's - they seen to give better lows.
one day i may bother to lot an esr frequency curve for a few caps, i have a scope now that has an ethernet interface. |
Thread Tools | |
Display Modes | |
