Remove_SMM... UEFI.
    I have a problem with the x250
    Problem with locked bios (supervisor password)
    i have Read the file using raspbery pi b+, modified the .bin file, but when i power on the laptop says f1 to go to bios, if i press it the laptop shuts down.
    I have tried multiple times still after pressing f1 the laptop shuts down, havent tried yet reflashing the original bios to it. but i believe nothing's wrong with it.
    the file.
    In the configuration i have replaced the following using UEFITool :
    LenovoTranslateService.fbd
    BootOption.fbd
    SystemPpisNeededByDxeCore.fbd
    this is the original read
    and this is the patched one
    If someone can help with this ill be more than gratefull
    And if someone needs any help with configuring the raspbery feel free to contact me
    internetpharmacydir.com
      Re: Remove_SMM... UEFI.
      Hello, can anyone help me unlock my lenovo t440?
      This is my original bios dump.
      I have exchanged three files with uefitool:
      BootOption.fbd
      The laptop, after replace these files, starts up but makes 5 sounds, pause and 5 sounds. When I pressed f1 it turns off.
      Thank you very much.
        BootOption.fbd
        In reference to the post above
        This is patched one:
        Thank you.
          Insert locked HDD
            I have finally received my eeprom programmer, and ... successfully achieved! password deleted on my x250, thanks to all who have helped
              Originally posted by RethoricalCheese View Post
              For that model you might need different file. I am not sure because I haven't compared 4th/5th gen to 6th/7th/8th gen yet. But try it first and let me know.
              Don't forget BootOptions and SystemPpisNeededByDxe which are found in some previous post in this topic.
              it works perfectly
                5 beeps two time - its a normal?
                  Yes, as long continues to the password pront, with the latest BIOS will always give checksum error ( 5 beeps x 2 ), If it ends up working then you have to put your original bios.
                    Laptop freeze, no "press space" message after enter key.
                      if there is no picture, the button marked in red must be pressed
                        image size is 8mb, but t440s need 16mb image.
                          is 16mb, bios tested and must work
                            Its working!! Thank you so much!
                              But this BIOS with clean ME work only for one laptop, other laptop freeze after thinkpad logo. When I press F1 key nothing happens, and laptop freeze.
                                I've been trying to make this work for my e580, but I don't think I understand things correctly. Can someone patch my bios for me? Please.
                                  I had someone help me with the supervisor password for a T450s previously. The patched bios used the allservice program, but its special in that it effectively nulls the hardware ID mechanism.
                                  I think this might be what some of you are looking for, no?
                                    Are there a patch for my lenovo x270 6th generation
                                      or how i can patch it,
                                      This us thé dump
                                        Hi
                                        Please help to patch bios Lenovo X260
                                          Originally posted by przemek_79 View Post
                                          Hi
                                          please give me feedback
