bios dump elitebook 840 g3
    Re: bios dump elitebook 840 g3
    Originally posted by sdr1 View Post
    Hi!
    Need help for unlock elitebook 840 G3 bios pass .
    Become a Badcaps supporter
    Thanks to all supporters.​
      Not work . Give me error tow long beep and tow short beep and remain in black screen .
      What make wrong ?
        What make wrong ?
        Most probably you have an issue with the programming of the chip, or it's not properly soldered to the board.
        Try again & check carefully all, use verification.
          i write original memory and laptop is power on but steel password .
          The password is stored in 25Q128xxx ic or in 25Q64xx ic ?
            25Q128xxx
              What's the point of writing back the original (locked) bios dump?
              Just flash the unlocked one, but make sure you do it properly this time.
                I write the loked bios for testing .
                  Interesting approach, your goal is to unlock the bios, but you do tests with the original dump which has a password. How is it going, is there any progress with this method?
                  Just joking
                    I wrote the unlocked bios just like the original one and laptop not work . I tried again with the original one to test if the chip still works. I tried again with the decoded bios and it doesn't work.
                      I need new BIOS for Elitebook 840 G3, motherboard is 6050a2822301-MB-A01, UMA version. After BIOS update client get error about ME cals it is outdated and now is no screen and fan is running on full spin. The best would be ME-region cleaned dump, I don't know is meregion is ok in my dump.
                        OK, try again:
                          Try:
                            Originally posted by Vesko356 View Post
                            Try:
                            Thank you, it is working well.
                              bios 840 G3
                              this only bios for i dont knoz why i try many bios but nothing
                              this bios work but with ssd shutdown i think me problem
                                Hello
                                I need unlocked bios, i try HPUnlocker but password is steel present.
                                  Originally posted by snork View Post
                                  Hello
                                      who can help me for my corrupted bios hp 840 g3 please
                                        i need help to unlock this bios i try many but no chance
                                        OKBALORD
                                          have you tried both hp unlock tools ? https://www.badcaps.net/forum/showthread.php?t=79956
