bios dump elitebook 840 g3
    Re: bios dump elitebook 840 g3
    Originally posted by raizenn27 View Post
    i have hp bios with password can you unlock..,thanks
    use RCUnlocker and unlock it yourself.
      try...
      I don't provide help for people using CH341A and a clip.
        Hello, Please I really this issue with computrace/absolute persistence set to active. Attached here is the bios dump
        840 g3
        6050a2892401 A01
          HP Elitebook 840 G3 BIOS dump
          Hello Guys I need Main BIOS dump for HP Elitebook 840 G3
          My original dump is brickt, i have no original BIOS dump.
          Pleas Help me.
          Mainboard:
          6050A2892401-MB-A01
          ProID: L3C65AV
          SN# 5CG6520S9B
          Thanks!
            Re: HP Elitebook 840 G3 BIOS dump
            Post your corrupt bios here.
            Become a Badcaps supporter
            Thanks to all supporters.
              I dont have, the bios chip is broken(blown)
                Please read the bios posting rules.You must post under a related thread if there is one.
                Use the forum search,you can often find a related post that way,then you don`t have to start a new thread.
                  OK sorry
                    can someone help me?
                      Search through this thread for a bios with clean ME firmware such as post #442. If a bios is titled outimage,ME Clean,clean ME they most likely have cleaned firmware.Use HP bios config utility to add missing DMI info
                        Unfortunately I don't know much about it...
                          You said your chip is broken,broken how,is it burned.Did you buy a new chip,do you have an SPI bios programmer
                            Yes, I wanted to remove the bios password and made the chip too hot. I already have a new chip and a SPI programmer
                              try the bios at post #442
                                Ok I'll try
                                  pleasse can somone clear the password .
                                    https://www.badcaps.net/forum/showth...ght=rcunlocker
                                      here you go.
                                        Can you explain the difference between my unlocked file and the file unlocked by RCUnlocker? Not trolling, just interested, since I am not very good with hex editors. Seems that RCUnlocker leaves some data behind, while my software doesn't.
                                          There is a difference, but this bios file only needs to intervene in the "U.s.e.r.C.r.e.d" area.
