bios dump elitebook 840 g3
    Re: HP 840 G3 bios needed
    Originally posted by imranromi View Post
    Try this
    Thanks will try it .
      Try this
      Kudos to you my friend it worked like a charm
        Try this
        Hola Imranromi please i need your help with this bios hp 840 g3 main p / n 6050A2822301-MB-A01 thank you very much.
          Try this.
            Try this.
            Thank you very much Imranromi, I programmed the bios with the bin that he gave me but I do not have an image, it is black while the fan starts walking at full speed, do you have any idea? very thankful
              Try this.
                Try this.
                Hello Inramroni how are you, I have loaded the bios that you sent me for the second time but still in the same state black image and fan at full speed after block mayus blink 5 times, I have also tried to load the original bios that has password but exactly the same happens ... the truth is I'm not interested in the mainboard just for me it's important to learn you have some idea I appreciate your patience.
                  Means original bios black image?Which programmer you use?
                    means original bios black image?which programmer you use?
                    ezp2010
                      Now original black image?
                        Yes not image with original bin
                          This thread have many bios use maybe someone give display lock or unlock use all
                            Ok, what do you think could be the problem?
                              Maybe your programmer bad or corrupt read i think this board bios chip WSOP8 right?
                                Originally posted by mcplslg123 View Post
                                your bios-pass cleared. Enjoy.
                                PS: Why dont you do it yourself?? Its so easy.
                                Could you tell me how to remove the password from the file? thank you
                                  Hello the bios chip is wson8 type with the pins hidden as the image .... I will get another programmer to perform other tests thanks.
                                    Yes right
                                      Hi Imranromi please i need your help with this bios hp 840 g3 main p / n 604B0178501-MB-A01 thank you very much.
                                        Try this
                                          black screen, fan full speed and hdd lamp lights yellow
