Thread Tools |
#1241 | |
City & State: London
My Country: UK
![]() Quote:
2.2.0.7 1.4.0 (someone advised that one) I've tried NeoProgrammer V2.2.0.8 I've also tried SkyGz CH341a Programmer V1.18 Colibri is the one I haven't but is it really going to be down to the software? |
#1242 | |
City & State: Bayern
My Country: Germany
Line Voltage: 230VAC 50Hz
![]() Quote:
And never had any problems. sudo flashrom -p ch341a_spi -c W25Q64.V -r /Path/To/Dump_01.bin |
#1243 |
City & State: uk
My Country: uk
![]() Lenovo T450, unlocker worked perfect 1st time. Many Thanks
#1244 |
My Country: UK
![]() So, having tried everything Windows has to offer I'm now trying with Linux.
Flashrom gives me the following though: Code:
Using clock_gettime for delay loops (clk_id: 1, resolution: 1ns). Found Winbond flash chip "W25Q128.V" (16384 kB, SPI) on ch341a_spi. Reading old flash chip contents... done. Erasing and writing flash chip... FAILED at 0x00000000! Expected=0xff, Found=0x00, failed byte count from 0x00000000-0x00000fff: 0xa57 ERASE FAILED! Reading current flash chip contents... done. Looking for another erase function. FAILED at 0x00000000! Expected=0xff, Found=0x00, failed byte count from 0x00000000-0x00007fff: 0x4a68 ERASE FAILED! Reading current flash chip contents... done. Looking for another erase function. FAILED at 0x00000000! Expected=0xff, Found=0x00, failed byte count from 0x00000000-0x0000ffff: 0x88a8 ERASE FAILED! Reading current flash chip contents... done. Looking for another erase function. FAILED at 0x00000000! Expected=0xff, Found=0x00, failed byte count from 0x00000000-0x00ffffff: 0x8d0c58 ERASE FAILED! Reading current flash chip contents... done. Looking for another erase function. FAILED at 0x00000001! Expected=0xff, Found=0x00, failed byte count from 0x00000000-0x00ffffff: 0x951344 ERASE FAILED! Reading current flash chip contents... done. Looking for another erase function. Looking for another erase function. Looking for another erase function. No usable erase functions left. FAILED! Uh oh. Erase/write failed. Checking if anything has changed. Reading current flash chip contents... done. Apparently at least some data has changed. Your flash chip is in an unknown state. Last edited by SMDFlea; 01-27-2022 at 03:45 AM.. |
#1245 |
City & State: Brussels
My Country: Belgium
![]() Hello Guys. I need a bios clean and with no password for Lenovo Thinkpad Carbon X1 Gen6
#1246 |
City & State: Zacatecas, Zacatecas.
My Country: Mexico
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
![]() @manutran
You need to read original BIOS, then patch it, do the unlock procedure and then program chip with original bios. |
#1247 |
City & State: York
My Country: UK
#1248 |
City & State: Lyon
My Country: France
![]() Hello everyone,
Any chance that this auto-patcher might be compliant with laptop models like T14s ? I'm able to gather a backup from the BIOS chip using a SOIC-8 clamp. I will try the auto-patcher first, but I'm totally open for your suggestions on these 10th generation models. Thanks ! |
#1249 | |
City & State: York
My Country: UK
![]() Quote:
Find a T14s thread to post in,if there isn`t one then start your own thread. |
#1250 | |
City & State: Lyon
My Country: France
![]() Quote:
I know that this auto-patcher seems to be limited to 8th generation, but I was hoping that "maybe", by chance, it might work similarly on 10th generation BIOS contents. So if I understand correctly, for now the answer is "maybe not" unfortunately. Thanks anyway. |
#1251 |
City & State: Chojna
My Country: Polend
#1252 |
City & State: New Delhi
My Country: India
![]() how to patch 8,9,10th gen laptops am using patch 0.2 motherboard is no display
#1253 | |
My Country: Germany
![]() Quote:
Reconnect the clip and try again. Otherwise there is a possibility that the chip is defective, which rarely happens, the things are otherwise quite robust. Good luck ... |
#1254 |
City & State: North York
My Country: Canada
![]() Would it be possible to remove password and computrace from this bios dump? I tried auto patcher but it doesn't work with file that i dumped. I get a checksum error then it restores the original data.
#1255 |
My Country: Mexico
![]() @richdee23
You should pay attention to the error, I suggest to READ chip and SAVE it, do this 3 times and then compare that all 3 files are exactly the same. If you use WinRAR you can compress all 3 files, open the compressed file and at the far right there’s a column named CRC32, if the values of all 3 files are the same, that means the files are identical. Are you using CH341A programmer? If so, try using Colibri software with it. Supervisor Password and CompuTrace setting is not stored in bios dump, that’s why it’s important to have a good bios backup as you will use this file to complete the procedure, the patched file is used temporarily just to perform the unlock. |
#1256 |
My Country: Canada
![]() I did a CRC32 check with winrar and out of 4 copies i've extracted they all match when using my CH341A programmer. So after i create the dump of my bios whats next? This is my first time doing this
#1257 |
My Country: Mexico
![]() @richdee23
Read post #1 of this thread, you may now be able to patch one of the verified bios copies. What’s your ThinkPad model and bios dump size? |
#1258 |
My Country: Canada
#1259 |
City & State: Budapest
My Country: Hungary
![]() Lenovo T540P and W541 bios password.
Have 2 bios chip. Which chip should I patch?? |
#1260 |
My Country: Germany
Thread Tools | |
