LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Originally posted by AAAC View Post
    @mysticusa
    You need a bios chip programmer, you can use CH341A (first make sure stock software does not corrupt reading/writing, if it does, use alternate software), EZP2019 or other programmer. Besides programmer I also recommend a SOP8 clip to prevent desoldering/soldering of bios chip. Some ThinkPad models use a WSON8 chip, which would prevent the use of clip, in this case you can solder wires from chip to programmer PCB adapter.
    What’s the ThinkPad model number?
    hello, I need bin file for bios dumping,Laptop is Thinkpad x1 carbon 7th generation, bios chip is MX25L25673G, I'm using CH341A programmer, can you help me ?
      @eminhaci17
      You should try to post additional information as the motherboard part number. I did check Telegram BIOS ARCHIVE and didn't find a compatible bios file, but you may find one it by searching this and/or other forums.
        Have a problem, might not be related to patcher:
        - Used patcher successfully
        - OA2 / OA3 ID intact
        - did a BIOS / EC / ME firmware update with fwupd (linux)
        - OA2 / OA3 ID missing
        Serial number is still intact. Anybody else had something like this?
        I have an original BIOS SPI dump, not sure if OA3 is stored there or in MEC and if it can be restored..
          Originally posted by hoaca388 View Post
          Try this but don´t work on Lenovo E590
            Try with this method : https://www.youtube.com/watch?v=FW-RLkzjAS8
            Become a Badcaps supporter
            Thanks to all supporters.
              hello
              I have lenovo p14s gen1 with svp "System Security: Supervisor password required"
              the auto patcher failed to find the lenovotranslateservice
              [2/2] LenovoTranslateService (GUID 826bcf56-bac4-43f4-8ea1-8cdf0a121abd)
              p14s read2.bin is corrupted or does not contain a valid dump.
              i have the bios dump verified twice.
              Please Help
                Originally posted by due View Post
                hello
                Please Help
                Maybe , this tool not support this model.
                  Does not work via autopatcher.
                  You can unlock via rewriting ITE8227 with Vertyanov or SVOD
                    hello
                    Please Help
                    P14s is not possible to be unlocked via BIOS patch.
                    You need MEC programmer like vertyanov, svod
                      Hello can someone help to unlock this thinkpada t480s i try the tool but its not work i cant find the patched file this the dump its i7 8gen
                        Originally posted by omaryou View Post
                        hello can someone help to unlock this thinkpada t480s i try the tool but its not work i cant find the patched file this the dump its i7 8gen
                        this is the file
                          Do you have any error messages from the software,have you installed python
                            No just zhen i pute the file on the patcher nothing hapen . No patcher file
                              Originally posted by smdflea View Post
                              do you have any error messages from the software,have you installed python
                              can you try pls withe my file
                                Install Python 3.8.5 first.
                                  ok my version is https://www.python.org/downloads/release/python-3102/ i have this system 64bit
                                    the same think :::: you can try patch the file please
                                      thinkpada t480s
                                        thinkpada t480s
                                        bro thank you its work )) yesssss can i know why the programe not work on my pc
                                          Hello can somone patch this 2 lenovo yoga x390 and x1 carbon pls
