lenovo g50-45 charging problem
    hi my friends
    lenovo g50-45
    MB NM-A281
    this machine working normally by dc adapter and battery
    but when i bulged the adapter windows say bulged in ,and charging but battery present don't changing
    i tried the battery on another machine and working normally
    any help
    pu4 (bq24737) values
    ACN 1 20.3
    ACP 2 20.3
    CMPOUT 3 0.02
    CMPIN 4 0.02
    ACOK 5 0.02
    ACDET 6 2.54
    IOUT 7 0.01
    SDA 8 3.33
    SCL 9 3.33
    ILIM 10 0.74
    BM# 11 0.74
    SRN 12 14.71
    SRP 13 13.9
    GND 14 0.01
    LODRV 15 0.01
    REGN 16 5.99
    BTST 17 14.4
    HIDRV 18 14.4
    PHASE 19 14.4
    VCC 20 20.3
    changed pu4 without any result
    thanks
    Re: lenovo g50-45 charging problem
    Check voltage in battery pin, and post.
      i will do
      thanks for replay
        your LODRV and HIDRV is not working. You need to check first your LOw and HIgh side fets connected to charger Ic.
          jbatt2
          pin 1,2 15v
          pin 3,4 3.3v
          pin5 .3v
          pin 6.7 gnd
          thanks
            Originally posted by menshawy View Post
            jbatt2
            pin 1,2 15v
            pin 3,4 3.3v
            pin5 .3v
            pin 6.7 gnd
            thanks
            these measurements are perfectly ok.
              thanks friend
              but what is the problem
              may be ite8586?
                another note
                JDCIN1 pin3 (ADAPTER_id) value is 0v
                but another mb is 1.9v
                  AD_ID must be ok for laptop to charge. So you need to probe AD_ID circuit.
                    thanks friend
                      this is ADAPTER_ID circuit
                      pq28 pins
                      pin1 0v
                      pin2 0v
                      pin3 0v
                      pin4 gnd
                      pin5 3.3
                      pin6 3.3
                      pr420 ,pr424 1m ohm ok and replaced
                      pr420 pin1 vin 20v ok
                      ue1(ite8586)pin73 0v-ADAPTER_ID
                      pin84 - ADAPTER_ID_on# 3.3 ok
                      no pins short to gnd
                      what can i do ?
                        thanks friend
                        you are right
                        problem was solved
                        pq11 pin4 HIDRV must be 19v not 15v
                        i fond pq8 pin4(gate) not connected with pr56,pr57 i removed pq8 and clean its place and soldered another mosfet
                        pq11 pin4 19v ok
                        charging is ok
                        thanks for all
