Hi I am working on a Razor notebook RZ09-0130 (Gaming unit). The initial problem was no display. The notebook turns on fine & after a while the fan start to run very fast but no display. I checked all main voltages VCORE to the Video chip, all fine. I reflowed the Video chip N16E-GT-A1 BGA IC., but still no luck. Since I was getting all the voltages, I assumed the video chip toi be defective & ordered this chip. Replaced with a brand new one, but still no luck. The notebook turns on fine but after a few minutes both the fans start to run very fast & LED in the front starts to flash continously. Removed all the peripherals but stil the same. I searched the web, no support or schematics diagram. Can anyone help me out in this repairs. Thanks
Razer Notebook no display
Re: Razer Notebook no display
Try those
Make a backup of your current bios!
Razer Blade 14 RZ09-0130 betty_R3 MB V3.0 MX25L1005.BIN = EC Firmware
Razer Blade 14 RZ09-0130 betty_R3 MB V3.0 MX25L6406.BIN = Main BIOS
Post #5 - https://www.badcaps.net/forum/showthread.php?t=76992Last edited by SMDFlea; 10-16-2020, 11:37 AM.
Originally posted by mferna14 View PostHey KvnTM., is it nesessary to re-program the EC Firmware too., & this is the smaller chip located just next to the main BOIS chip, isn't it? your reply will be much appreciated.
Yes it should be a small 8 pin ic close to the EC. Marking should be MX25L1005.
Does it work with the new bios alone? Then you won‘t have to flash the EC firmware as it is already fine.
I know this is an old thread but working on the same machine RZ09-0130. It came in with a power problem and then had a single fan spin on pressing power button. I reflashed the bios and EC and now I get slow blinking front light (red on battery and green on charger) and fan spin. After a while fans goto full speed but no display. No HDMI output or mouse light via USB. Any ideas?
thanks
